Landscape Rake + BX25
Flienlow
Kubota BX25D, Kubota U25 mini EX, SVL75,Landpride Grapple,Landpride grading scra
Mar 9, 2015
352
snohomish
Looking for suggestions on which size landscape take I should get for the BX?
L4740
222
3rd Rock From The Sun
I run a Woods 5' with gauge wheels on my BX23. This is the model for a sub compact, not a full size one. I have been very pleased with it. Not sure if they make them any longer or not.
2,551
I would suggest the 5 footer too, any smaller with a rake, you are wasting time, depending on WHAT you want to rake, you might be able to pull a 6 footer
Flienlow
Mar 9, 2015
352
snohomish
I was wondering if a six-footerwould be too big? tractor supply has them stacked up but no five Footers in stock.
RonBoyBX25D
B2650, LP Grapple, Bro-Tek spacers, QH, Box Blade, Landscape Rake, RB, and 1560G
Aug 1, 2015
477
Minneapolis, MN
i run a LR1672 from Landpride and it works well on the driveway, just added gauge wheels for my driveway project. I like being able to angle and windrow out the rocks to the side then pull the clean back to the center for the crown.
Flienlow
Mar 9, 2015
352
snohomish
How does the bx handle the 5' rake? Would it handle more? Do you wish you had a 6'?
L4740
222
My BX23 handles the 5' just fine. No problems. Would it handle a 6'? Probably for most applications, but I have had no reason to ever wish I had a wider one. At full angle it still covers my tracks. For me, that's all that matters. Plus I am able to get into areas I couldn't with a 6'.
Flienlow
Mar 9, 2015
352
snohomish
Thanks. I found a Tractor Supply Store that just happens to have a 5 footer in stock. I guess normally they do not carry them in my area. I am going to get it tonight.
Flienlow
Mar 9, 2015
352
snohomish
I guess Ill find out. Brought a new 5' tonight. It looks like it will swing around.
RonBoyBX25D
Aug 1, 2015
477
Minneapolis, MN
I have never tried to turn mine around backwards since I have the gauge wheels on mine. I guess you could reverse it before you hook it to the tractor.
I just added the gauge wheels, that might make a difference. Now I have to plan, nice to have a QH if I need to drop it to turn around.
RonBoyBX25D
Aug 1, 2015
477
Minneapolis, MN
I think the gauge wheels are worth it on a BX and 1/4" valving. Would guess less of a need with position control. It worked well to level the driveway in prep for the class 5.
clay45
L2050DT, TSC 5ft Rake, Tartar 5ft rototiller, TSC Middlebuster, TSC CarryAll
Feb 6, 2015
279
SC
Let me know if they are worth getting.
I wish I had not purchased mine so far. Time will tell. But the landscape rake itself has been very useful in collecting unearthed roots, picking trash and rubble from dewberry and briar patches, pushing up brush piles, etc.
