Tractor step
bdale
47
N.C.
Does any one know if they make a shorter step to fit the B2650, the original one hits the MMM when raised.
TripleR
Sep 16, 2011
1,911
SE Missouri
I've seen people use these by Bully on theirs.
That or a good welder can shorten yours.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
I have a B2650 with mmm also and mine does not hit the step. Might want to make sure that everything is mounted as it should be.
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Steps come welded on the tractor. They dont change steps when some one wants to mount a mmm.
bdale
47
N.C.
My step is a bolt on;)
Also if your tractor has turf tires it is equipped with bump stop extensions on the rear of the deck to keep it from lifting to far and interfering with the rear tires mine has R4's No need for bump stop extensions so my deck will lift a little higher.
