I bought a 1998 Kubota B1700 with 115 hours on it (looks like new). However, I was dumping a heavy load of dirt in a tight area while turning the front wheels really sharp (near the edge of a bank), and afterward I noticed a lot of hydraulic oil spilled onto the ground.
I looked under the tractor and saw a pretty good amount of oil around the rear of the front transmission, just under where the steering column is.
So I took the mat off the deck and noticed a lot of oil had collected underneath it.
I removed the instrument panel and shroud so I could get to the steering components.
I noticed the oil seemed to be coming from the right side. I suspect the leak is coming from the cover with the four bolts on the right side of the steering column (shown below) but I'm still uncertain. This appears to me to be the "most likely" suspect.
Is this a common problem area for 1998 Kubota's, or is it possible there's a leaking seal up underneath the steering column where I can't see? I find no external oil up high. It's all down low on the right side. The tractor was garaged it's entire life and has very low hours. It's difficult for me to imagine a gasket would already be leaking this much oil (about 1/4 cup in perhaps 5 minutes of heavy pressure on the hydraulic system while sharply turning the wheel). Also, nearest I can tell, the relief valve is designed to divert the oil to the reservoir as opposed to spilling it out onto the ground. Is this correct?
Thanks![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![UndersideAtSteeringColumn.jpg UndersideAtSteeringColumn.jpg](https://www.orangetractortalks.com/forums/data/attachments/20/20045-5b59519171f00722d975e4a854104260.jpg)
![TopDeck.jpg TopDeck.jpg](https://www.orangetractortalks.com/forums/data/attachments/20/20046-455c2fd02cfeb1c7a0e5e37718bbd4c5.jpg)
![SteeringColumn.jpg SteeringColumn.jpg](https://www.orangetractortalks.com/forums/data/attachments/20/20047-c71d609a81ee1f6df2730d781895ba47.jpg)
![GasketLeak.jpg GasketLeak.jpg](https://www.orangetractortalks.com/forums/data/attachments/20/20048-4342a51be1210b4a0229125ccafc0178.jpg)
Thanks
