2 Kubota G1900 S tractors, one with an RC48 deck (Tractor 1) and the other with an RG60 deck (Tractor 2). Both 3 cylinder diesel engines run great. Both are HST with hydraulic deck/plow lift and shaft-drive mower decks. Both tractors are 4-wheel steering. Tractor 1 has been my primary mower and I recently acquired Tractor 2. Recent oil (Rotella), hydraulic fluid (Kubota SUDT), and coolant changes. No drips from either machine. Both seats are in excellent shape.
Tractor 1. 985 hours. 48" deck is in excellent shape. Has engine block heater. Runs and operates very nicely.
Tractor 2. Working hour meter reads 64 hours, but I believe the gauge cluster was replaced. It obviously has more than 64 hours. I have no idea how many, though. Starts easy and runs smooth and strong. 60" deck has Kubota spring assist (transfers weight to frame/wheels for added traction). Has some rust in deck, but can be fairly easily patched. Also has a slight fluid leak on top of engine. Seems slight and doesn't affect much. Brand new ag tires on rear.
G2001 Snow Plow. Good condition snow plow works great with these machines. Hydraulic lift makes plowing snow fun! Includes wheel weights and chains.
If you would like a link to a video of each tractor starting, running, PTO engaging, etc., let me know.
Parts mower. If you purchase both mowers, I'll throw in a parts mower. No engine, but good hydraulics, rear end, wheels, and miscellaneous parts. I've also collected a couple other parts decks and various other parts I'll throw in if both mowers are purchased.
Tractor 1 = $2,200
Tractor 2 = $1,850
Snow plow = $350
Purchased together, including parts mower and other parts = $4,200.
Tractor 1 = $2,200
Tractor 2 = $1,850
Snow plow = $350
