Busted radiator l3010
Bill1864
Georgia
Can someone tell me how hard it is to pull out the radiator. It got dark before I could start looking at how to remove it. If anyone could give me a starting point it would be helpful.
Thanks
5,111
I think its fairly easy, but I think working on most of a Kubota is easy.
The only way to know the exact procedure is to get the WSM, but I would think a radiator swap shouldn't have any real tricks to it. ;)
meanjean
Kubota MX4700
Aug 10, 2010
922
Hazelridge, Manitoba
Thanks
Assuming it's a similar design to my tractor (L1801) theres really not much to it.
Drain the rad, remove top and bottom hoses, remove anything else connected to it. It's a coupe of nuts located at the bottom of each corner and out she comes.
Bill1864
Georgia
I was able to get the radiator out today. I found out you have to remove the hood,grill,battery tray and then the radiator support. Thought it was interesting how the radiator just sits in place with four tabs.
5,111
Can someone tell me what could be wrong with my Kubota
It smokes white when under pressure
Start a new thread, and give more information.
Like is it over heating, or using water?
