L2250DT oil pan removal
rlb9585
Kubota L2250DT
Mar 29, 2015
Bucyrus, KS
I just picked up a L2250DT tractor, and it had a real bad, I thought was, fuel knock. I put new injectors in it and that didn't change a bit, so I decided to pull the head off and found an issue with the front piston/cylinder. My question is can I get the oil pan off with the engine still in the tractor? To me it looks like if I can get the front driveline out of the way I could pull the pan off and knock that piston out of there, but not sure if this is possible. Thanks for the help.
Randy
4,519
You should be able to get it out. I Happen to be about 60ft from one. Will look after dinner and see what it takes to remove it. If I remember right it's a two piece pan with the propellor shaft running through the middle of it. Either removing the motor or dropping from the bottom is gonna be a great big pita
rlb9585
Kubota L2250DT
Mar 29, 2015
Bucyrus, KS
Thanks I would really appreciate it. I would think there was a way to get it out, but just haven't messed with these enough to know for sure.
4,519
It's my dad's tractor. First time I've been on it in ten years was yesterday to unload my tool box. I got charging, starter and electrical issues to fix on it this week. :rolleyes:
4,519
Got some pics for ya, for what your looking to get into. If you have the fel, you'll want to remove it for ease of access to the engine. First pic shows the propeller shaft going in between the oil pan. The orange subframe support and the propellor shaft need to be removed
Then directly opposite the frame you can see and get to the bolts for the oil pan
And judging by the second pic, I found my oil leak :rolleyes: guess that's going on to the to do list for later on down the road :eek: and it's missing a subframe bolt. I need to quit looking at it :rolleyes: :):D;)
rlb9585
Kubota L2250DT
Mar 29, 2015
Bucyrus, KS
Thanks, does it look like its a two piece shaft? It would be nice if there was like a slip yoke somewhere to pull that off to keep from disassembling to much stuff. Mine is covered in grease, oil and dirt, so its hard to tell exactly what I'm working with.
4,519
Unfortunately it doesn't look like a slip shaft. Looks like a solid shaft. Here's where it ties to the front
Here's where it ties to the tranny
4,519
Here's a couple pics of the shaft. Can't locate dads drop light so I'm taking pics to see what's under there
