Front tires for snow
Swando
Kubota L3301 tractor
Mar 3, 2017
35
Fairfield, Idaho
I am looking into finding some 27x8:50x15 front tires for my l3301. I think some kind of snow tires would be better than the Ag tread. Any ideas? I have searched the web and have not found any tires I like.
2,821
As it is my understanding if your L is a 4wd then what you have be more concerned about is the wheel ratio front to rear. Remember the axles have to turn at the same ratios and changing out the tire size will muck that up, and den ya gots dem big troubles. What you have to understand tire size does not always equate to the rolling size, meaning even with in the same tire size one may be taller or shorter than. And this changes the rolling ratio front to back, I know it sounds like double talk, Im sure somebody else can explain it better
If its 2wd then what ever you stick on is ok.
bearskinner
Sep 1, 2014
925
238
N. Idaho
Basically running different sized fronts WILL break Axles..... to start.
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
Aside the 4wd issue, I did a cursory search for the European style tractor snow tires, and couldn't find anything for cut sized machines.
BAP
Dec 31, 2012
2,531
670
Why do you want snow tires on the front?
Swando
Mar 3, 2017
35
Fairfield, Idaho
Thanks for the tire sizing information. My fronts are 50% or less. Last owner must have driven on pavement or concrete. I wouldn't expect that much wear @ 1600 hrs. Need a new set before next winter.
mbu
260
United States
How about getting a set of chains for the rear tires? If you have R4 tires, they make a chain that keep it out of the "valleys".
Swando
Mar 3, 2017
35
Fairfield, Idaho
Re: rear tire chains
Rear tires chains sounds like a good idea. We often have deep wet snow falls. I will search for a set.
L3010HST
L3010HST w/LA481 loader; Land Pride RB2672 Blade and RF2060 Rotary
Apr 29, 2013
55
PNW
I picked up a set of these Duo-ladder style (which are the recommended type for AG and/or R4). They made a big difference during this winter for me, especially being I'm not running any ballast in the rears for more traction.
Was thinking chains for the fronts too, but my Kubota Dealer said Kubota doesn't recommend that. Anyone know why that is? Sure would help in steering while I'm pushing.
Sorry picture is sideways. It's how it uploaded :confused:
sagor
Jan 9, 2017
272
50
Sudbury, ON, Canada
I think it is the same reason as not running 4WD on hard pavement -hard on the tires and drive mechanism. The front tires (in 4WD) are made to spin (travel distance) just a little bit faster than the back, and accounts for slippage when on snow/ice/gravel. Also, when turning, one front tire has to slip as it travels a different distance with the same RPM of the tires. Putting chains on both front and back (or even just the front) will tend to remove that "slippage" on the front tires, making it as if you were driving in locked 4WD on a harder surface, causing more strain on the transmission gears/gearbox/differential....
L3010HST
Apr 29, 2013
55
PNW
Good explanation, makes sense, thanks.
WFM
L3800
Apr 5, 2013
1,191
501
Porter Maine
I have a cousin that has a 45hp john deere , he bought chains for the front tires for winter. He has a steep paved driveway, it melts and freezes and ices over. He said the chains have made it possible to bucket all of his driveway.
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
Ags on the front of Cub Cadets
are reversed for better traction and steering in snow
Just an observation.
I would go with chains on the front.
SDT
multiple and various
Apr 15, 2018
3,084
925
SE, IN
Won't hurt anything in snow but you should not run chains on all wheels year round.
FWIW: Most tire chains will cause tires, F or R, to slip MUCH more easily on paved surfaces, wet or dry, if not snow covered.
BTDT.
SDT
SidecarFlip
Banned
546
What I with my M9000 with R1's. Chains on the front only, not the rear and I can plow with no issue... been doing that for about 10 years now with no issues but 2 sets of chains...
