I have a B8200 4wd and I had my pinion seal on the front axle start leaking well after tearing it apart I found the reason it was leaking was because the bearing were very loose so I went farther into and found that the teeth on the pinion were badly chipped so I started looking for a good used one as it seems most of those parts are not available new. I located a place in Texas that said they had what I needed so they shipped it to me.
Here's where my problem is. The pinion they sent me came with the bearings a collar between the bearings and a triangular plate that has the seal in it and the plate bolts to the housing to hold the pinion in. My tractor has a much longer pinion that goes in a tube that has triangular flanges on both ends. They are claiming I don't have a B8200 but the tag on the left side clearly states in English that it is a B8200D.
Here's where I need help. I am needing someone with a B8200 to tell me if they have a cast iron tube bolted to the axle housing that is 4 3/16" from flange to flange or if they just have a thin plate about 1/2" thick bolted there.
Thanks in advance to anyone that can help
