tcmeyers
B2601HSD, LA434 loader, Skid Steer Quick Attach (SSQA), B2324 bucket, BH70
On my BH70 backhoe unit (on Kubota B2601HSD) the large pivot pin (25 mm diameter) on the square tube that that sets the thumb position is stuck. That pin is supposed to be pinned to the frame of the backhoe arm with a small diameter bolt, with the bushing at the not-thumb end of the tube doing the pivot action. That bushing is frozen to the large pin. Forcing the tube to pivot only succeeded to shear the small bolt into 3 pieces. That makes the thumb usable now, but I’d like to fix it properly. Hammering on and drenching with penetrating rust remover hasn’t freed the pin from the bushing.
What should I try next?
