Shawn T. W
Dec 9, 2024
832
1,507
SW Missouri Ozarks
I have a similar model, mines 65 gallons and 12' - 7 nozzle boom, but has a "6 roller" PTO driven pump ... Which also fits on my QH.
junhy
I’m mostly using a small tractor for the basic stuff around the property.
Aug 24, 2026
Europe
Hammers swapped for Y-Blades. What I have learned is:
Hammers are better for woody weeds and trashy cutting in overgrown undergrowth, but not so great with thick pasture grasses or stringy weeds that tend to wrap around the hammers, or worse yet, around the drum. HOWEVER, they do an excellent job on short grass (lawn).
Y-Blades are worthless in viney/woody weeds because they don’t have enough inertia and tend to just bounce off. Too sharp is a thing on mower blades because of the quick wear that occurs on a sharp edge. The blades’ original edge was not very sharp at all, so I tweaked them a bit to maybe do a better job with tougher weeds. They excel in tall thick grass and stringy weeds, but leave a lot to be desired for cutting lawn type grass because the shape of the cut leaves very visible ridges under each knife path. No real surprise there, though.
I have seen some brands with L blades which should leave a much better finish on a lawn, and maybe work okay in light weeds too.
I’m still exploring mowing options for when my 15 year old Husqvarna rider bites the dust. SUzie can’t do a belly mower (no midmount PTO) so unless I get a rear finish mower, I’ll likely just get another rider or Zturn.
That’s a really useful comparison. I’ve always wondered how much difference the blade style actually makes once you get into taller grass and weeds. The part about the hammers wrapping with stringy weeds is something I hadn’t really considered, but I can see how that would become a pain pretty quickly. It sounds like the Y-blades would make more sense for rough grass and pasture, while the hammers are the better all-around choice when there’s a lot of woody stuff mixed in.
I’d be interested to hear how the L blades work out if you get a chance to try them. Getting a decent finish without giving up too much ability to handle light weeds seems like the sweet spot. And a 15-year-old Husqvarna has definitely earned some retirement planning by now!
NCL4701, Sounds like the classic “just get the tractor and do what I tell you” job. At least she had you properly equipped with the forks and basket. Now I’m curious what kind of shrubs were around the front of the house after all that cleaning - https://botanapp.com/identifier/shrubs might come very useful if there are any mystery plants in the way.
LBZ
'25 GL6060
Sep 17, 2025
53
108
Iowa
I think you must have some thicker grasses and weeds in Alabama than we have in southern Iowa. I've run hammer blades through pasture grass that hadn't been mowed for 2 or 3 years, multifloro rose and small saplings. The only thing that has fouled the hammer blades has been a section of woven wire fence.
Bearcatrp
Mar 28, 2023
1,389
1,009
Minnesota
Haven’t been on mine since the hip replacement beginning of the month. Cut grass before the surgery. Took it for a ride to see how the new hip handles the bumps. Did good. Will be cutting grass this week.
Reactions: 7 users
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket,
May 4, 2026
41
31
Missouri
Nice setup. I am looking at adding a sprayer but am undecided on one for the RTV or, a three point version. I do like the fact yours fits oh the quick hitch.
I have the 45 gallon UTV version with 7 nozzles in an RTV 1100. My dad purchased both a number of years ago. Sprayer works fine with a couple of issues:
1. Quality control on the boom isn't the best. One end higher than the other do to an off angle weld/assembly. Even tried a different boom but had same problem. Eventually had a local welding shop adjust/fix it.
2. Quality of the plastic manifold isn't the best. Chemicals are hard on it so I have to replace it about every 3 years as the pressure and/or boom control start having issues. Not a hard job but has to be done.
Otherwise, the RTV handles it great. Doesn't even notice there's a tank full of liquid in the back. Local Kubota dealer installed an on/off switch on the dash. It's also nice being able to spray in a cab and avoid any drift/odor.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,747
4,623
PEI Canada
Thank you for the insight. Definitely something to keep in mine.
6,864
Spent about 6 hours finishing cleanup from recent storms, mostly leftovers from one storm a few weeks ago. All the trails and yards were cleared and big stuff taken care of shortly after the storm that did the vast majority of damage. Today was cleaning up smaller stuff by the road, pond, and woods adjacent to the yards where there was a good bit of limbs and busted small trees that were visually offensive. Also had a moderate amount of pruning dead branches that were busted but not on the ground.
Since it was all 5”- stuff either in or beside the woods, drove around with chipper and small chainsaw to chip everything in place. IMG_0514.jpeg IMG_0520.jpeg After finishing the cleanup, dropped the loader and chipper to swap to the bush hog. Started bush hogging the little fields with trees that we keep in grass. Didn’t expect to finish, but the 1.5 hours I spent on it today is 1.5 hours I don’t have to spend on it tomorrow. IMG_0522.jpeg
Reactions: 6 users
Old_Paint
Dec 5, 2020
2,056
2,352
AL
I wish
I'm interested in the L shaped flails you mentioned. That's what I was looking for originally but could only find really heavy duty versions - 8" long, 3/8" thick - so I've gone with Y blades. Do you have a link to where you saw the L blades you could share ?
I wish I had bookmarked the page, but looks like I have to struggle through the search AI that shows me everything EXCEPT what I asked for. Blades are pretty hard stuff and making a set might be outside my skill set and capabilities. I don’t think I have enough know how nor a forge to harden them, but mild steel would be easy to bend and drill. A forge is easy enough to cobble together. Keeping the weights spot on would be critical too. I distinctly remember seeing them, but don’t remember what brand they were, nor what got me to that page. Gonna try to find them again, but maybe you’re right about them being too big for my little mower. Making 48 identical blades would probably be a bit time consuming, but I bet the originals had quite a bit of weight discrepancies. The mass of each blade is so low that they probably wouldn’t have much vibration on the drum because of the phasing of the mounts on the drum.
Old_Paint
Dec 5, 2020
2,056
2,352
AL
Long grass tends to build up small clumps around the neck of the hammer and then continue growing on the shank until it fills up the spoon. A little woody stuff will clear them pretty quickly., so cutting perimeter stuff is great with the hammers. The Y-blades are much narrower and don’t seem to build up as bad as the hammers do.
The most annoying weeds in the fields Im cutting are nearly as bad as running over nylon baling mesh. They are TOUGH. I couldn’t tell much difference whether green or dried. But they don’t clog the hammers. The good grasses do that. I also found that the Y-blades don’t seem to liif up baling mesh as much either. I’m guessing that’s because they don’t create as much air flow as the hammers.
Paul Allwood
Kubota B7200HSTD, homemade FEL, front flail mower, forks & ballast box, tiller
Jul 8, 2025
790
1,466
Baranduda, Victoria, Australia
I wish
I hadn't considered making a set of blades but it might be possible. The hardest part would be using the right steel then getting the hardening and tempering right. But someone makes them, so it's obviously possible.
Paul Allwood
Jul 8, 2025
790
1,466
Finished moving our rocks today into a single large pile with several deposited and arranged in a new garden near the back of the house. We collected these rocks from a friend's farm 20 years ago when we were fitter and stronger and didn't have a tractor to help.
We have a wet patch that I've been driving through a bit with the rocks making a nice mess. Our neighbour up the hill from us has a couple of large tanks and when they're full the overflow runs right through here. It means that this spot sees all the rain from all of his roof that feeds these tanks. It gets pretty soggy underfoot, but this is the first time I've driven through it a lot when it's wet. Maybe one day he and I will dig a drain or re-route his tank overflows.
This was the second last trip. I got bogged on the next one, even with the diff lock engaged. I reversed, picked a new track, and all was good. Glad I removed the turf tyres.
Paul Allwood
Jul 8, 2025
790
1,466
All those rocks I moved with the super-tractor....here's where we put some of them. Add a load of soil and plant some plants (my wife), just like that we have a garden.
Reactions: 11 users
Speed25
L2501(sold) - BX25D
Apr 23, 2024
350
536
NC
Had 20 yards of screened top soil delivered to take care of some low spots and erosion around the property. I miss the L2501 for moving more dirt in one scoop, but the BX was a lot more useful getting into the tight and sloped areas. Overall, the job was quicker using the BX than it would've been with the L due to the lower center of gravity and usability in those off-camber areas. Sure is a useful glorified lawnmower!! :ROFLMAO:
