What size tractor?
6,307
OK, I have to ask... why are you mowing the field ? I have farmers that pay for 6-10 acre fields near me so instead of YOU cutting grass, you could be paid and watch crops being grown and harvested.
Joisey
Kubota L47 TLB
May 31, 2015
252
173
Wild, Wonderful West Virginia
I have a 2001 Husqvarna ZTH-6125 zero turn mower that I bought new. It is now 25 years old. My only wish is that I had bought it 10 years earlier.
The deck is adjustable from 3 to 6 inches (IIRC) and with sharp blades and the deck height set to 3 inches it will cut 12 inch high DRY grass with ease, even with its 61 inch cut. It will cut wet grass well, but not as smoothly as dry grass.
The beginning of the second season I had to replace all the hydraulic lines, as they leaked at the ferrules. Poor design on the part of Husqvarna. One coil went bad just last year, I replaced both with new Kawasaki units. Other than that, just maintenance items. The engine burns no oil.
For all but the last 3 years I cut 10 acres of grass weekly. The mower cut my time in the seat in half compared to a tractor and bush hog. Push mowing/weed eating is near zero because you can cut that close.
WhatnxtBX
BX2380
Jun 10, 2019
36
Lk Stevens, WA
I have 5 acers to mow once a week and do it with my BX2380, MMM 60" and a offset 60" pull behind (mounted to the side) finishing mower. I opted for cutting wider rather than cutting faster as my ground is not flat and has mole hills. With the offset mower, I can get under the trees and mow close to the creek. Around the house, about 2 acers, I just use the BX with MMM.
biketopia
Feb 15, 2024
435
467
Warrenton VA
When we bought our house on 5 acres of old cow pasture, I originally ran the B2650 with a 72" finish mower and an old, sketchy ridder. The next season i was on the hunt for a zero turn. Bought a used Scag Turf Tiger 61" cut and man....that thing does such a nice job and is sooooo much faster and nimble, I don't know why everyone doesn't use one. I can cut our 5 acres in 2 hours or less most days, unless it's early spring when the grass is thick and wet.
Joisey
Kubota L47 TLB
May 31, 2015
252
173
One bad point with zero turn mowers is when they are used on hills of any significant angle. They are fine until you have to change direction, even a little bit, and then they go like a dart, straight downhill and out of control. When I bought my zero turn I lived in NJ, where everything is flat or nearly so. Now I live in WV, where you have two choices of direction, up or down.
As much as I love that mower, I'll have to trade her in on a small Kubota B series 4wd tractor with a belly mower. I've come way too close to 20-30 foot drops, and I don't bounce at 70 years old the way I did when I was 25
