Hello to all.
I'm new to forums in general....and I did search past forums before I started a new post....found some of the past links were dead.
I'm new to Kubota. I bought (from a dealer) a 2002 ZD21 with 1450 hours, but it has a deck lift issue. Seems it only works for a few minutes directly after startup.
Motor is a D782, it's clean, all original. Dealer had all the service records, seemed to be well taken care of. Both transmissions pull evenly, are strong, no noises, fluid is clean. Yet, the deck only works briefly when cold.
I pulled the lift cylinder and changed both seals. I installed a used (working) hydro lift deck unit off Ebay. I haven't changed the hydraulic oil and filter yet, but plan to do so sometime soon.
I let it run for several minutes before trying the deck lift, but there really wasn't any movement....by then it was already hot. I'll try again in the morning, but obviously it's still not working correctly. I'm not sure if there is a bleeding procedure.....my neighbor has several Kubotas and said the air will work itself out as it runs.....just let it idle awhile.
I did see in past forums, suggestions on cleaning or inspection the hydro strainers, or internal screen filters, but I didn't see any follow up if this resolved their issue.
I don't mind changing o-rings or seals...if I knew what i was looking for.
If anyone has resolved a similar issue, I would appreciate suggestions and link to some thing I missed in the past forums.
Respectfully,
Lawrence
Respectfully,
Lawrence
