BX2200D no power steering
6acres
BX 2200D, 4' bush hog, 4' box blade, HF backhoe?
Oct 5, 2011
29
tangipahoa,la.
Kubota BX2200D with front end loader, 2002 model with 163 hours.
I have no power steering, it will turn but very hard. The other hydraulics work fine.
I measured the hydraulic supply to the power steering and it read 1500#, which is correct according to the dealer.
I removed the power steering cylinder and put the gauge on each side it read about 1000# when turning the wheel hard in that direction.
I ran the cylinder to each end with the other side open and no fluid leaked through.
With no load on the steering cylinder I found it is easier to turn with the motor (pump) off ???
I have read what was said about that model having a bad steering cylinder, but my tests do not show it to be a problem (?), although I am at a loss to figure it out.
Any help would be greatly appreciated.
6acres
Oct 5, 2011
29
tangipahoa,la.
Thanks for the info. Since then, I bought a service manual and found that the hoses to the steering control (source & return) were swapped. How or why that happened is a mystery, they were not the correct hoses either, so I had to order the correct ones from Kubota. They went on easily and now the power steering works fine.
Radarjray62
kubota BX2200D
Jul 28, 2026
Bigkid1962@9635
I have seen hydraulic lines collapse internally which limit fluid flow and creat a back pressure on a return line. So I take off line and blow it own with an air wand to check it out then replace if restriction found.
10,982
Come on now, replying to 15 year old posts, is a bit much!
10,982
Sometimes a person will use search to solve a problem just like me came across old post that are relevant to a problem and post an idea they have had success with that might help others. Thank you sir and have a great day.
Sorry your really not going to like my reply but using air on a Hydraulic hose to check for intenal collapse is a bit silly.
You're using an air wand with very little pressure, less than 100lbs, to check a hose that it's working pressure is in the 2500lbs minimum range.
Even if it was collapsed you could not tell.
And in all my years I've never seen a collapsed hydraulic pressure hose, suction yes, pressure no.
