rocker shaft assembly for a L185DT?
rhouseksa
L 185DT
Jun 10, 2026
Eagle Rock, MO
I have a L185DT that I bought with no lift on the 3 point hitch. I have checked &/or repaired everything the Kubota manual recommends and I am now down to the Rocker Shaft Assembly. Is anyone aware of a complete rocker shaft assembly overhaul kit with bushings, springs and O rings that is available for the L series? Have any of you torn into one of these thing that can give me advice on what to expect in the overhaul. This machine has about 2600 hours on it but looks like it was used very hard, Thanks in advance, Jeff
whitetiger
Nov 20, 2011
3,650
2,071
Kansas City, KS
What is the hydraulic oil pressure to the 3-point control valve?
