Newbie and the Bota Water-Filter separator
Denny Smith
Kubota BX2380 with snowblower (2816), front loader (LA344S)
Nov 19, 2025
22
Michigan U.P.
Hi y'all, kind of a weird question:
So, up in the U.P, I have a BX2380 and am installing the Bota Water-Filter separator. Last winter, I was using Howes Diesel treatment, kept the tank full, and had no problems. I do use the block heater for 1 hour before starting too.. Now, I'm wondering: if I'm using the water-separator, do I still need Howes Diesel treatment? Does it make sense to keep using it? Are the two things even related? 'ppreciate any thoughts you may have on that. Best...D
10,923
The treatment and the filter don't do the same things.
So it's up to you if you think you need to treat the fuel.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,137
1,114
E.
I would keep using it.
It's relatively cheap and helps prevents fuel from gelling in cold weather and supposed to lubricate fuel injectors.
I would also encourage use of a biocide.
MapleLeafFarmer
Dec 2, 2019
1,137
1,114
E.
I hadn't considered any biocide. Can you tell me of a few common ones? Thx.!
This is what i use. Based on the shelf space, this stuff gets in our stores it seems to be the most common. Works well for me.
I would use whatever is most common in your area on the shelf. There seems to be unlimited choices out there for biocides. I consider it cheap insurance versus an expensive repair or downtime when time is critical.
Denny Smith
Nov 19, 2025
22
Michigan U.P.
Thank you. I looked up a few on the net, and all of 'em said for larger storage tanks, or, smaller fuel containers ( 5 gal-if it's gonna' sit more than 6 months). At this point, I have maybe one that'll sit for that long, and I can feed that into the shop diesel heater I suspect. I'll get some anyways so it's 1 more thing to protect the system. Aint' that expensive, at least compared to bad things happenin'. Thanks again....D
Shawn T. W
Dec 9, 2024
769
1,402
SW Missouri Ozarks
The Howes chemically separates out the water, the filter/separator will trap it in the bottom, but ... Water can freeze, and expand ... So don't let it build up while it's warm out, ice crystals will also plug up a filter, best to treat and filter prior to putting in tractor tank, if you have trouble with quality fuel supply ...
Denny Smith
Nov 19, 2025
22
Michigan U.P.
Yep, I treat it in the storage container ( 5 gal), and the #1 diesel seems to be good from a much-used pump in town. No issues last winter, and working to make sure I don't have any going foward. Thanks!
