Determining rear ballast weight ?
Farm Fun
L3902HST R14 tires, LA526 loader, LandPride QH16, LandPride 1060 combo bucket
May 4, 2026
31
23
Missouri
Been trying to determine how much ballast I want to add to the rear of the L3902 to offset the 526 loader. However the tractor and loader manuals really don't help with determining the amount. So here is my situation:
1. Loader will be used for basic jobs; dirt, gravel, brush. (have the Land Pride 60inch combination bucket)
2. QuickHitch is 70 lbs
3. Heavy hitch weight bracket is 65 lbs
Thinking I would start with 8 weights at 40 lbs each. 70 + 65 + 320 = 455 lbs total.
Does this sound reasonable? Thanks.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,163
1,157
E.
Lots of variables to consider but generally thinking in my world you would be close but a little on the light side
Bee-Positive
Nov 16, 2022
1,021
963
Amsterdam, NY
An LA526 will lift 1,144 lbs. at the pins. The 3 pt. will lift 1,435 @ 24" back. I'd put 600 - 700 out back.
Try different weights and see what you feel safe with. I run less in the winter for snow and more in the summer for dirt/gravel and digging.
Shawn T. W
Dec 9, 2024
790
1,417
SW Missouri Ozarks
I'm of the belief that you should see what backhoe fits it ... Then see how much that weighs ... Then you can add a little to that, as your suitcase weights will be closer to the back of the tractor than if you had a backhoe mounted ... As if you have a Tractor Loader Backhoe (TLB) there really isn't a good way to add more ballast to it, so it needs to be adequate for what the loader can lift, obviously if your using suitcase weights, you can adjust how many you put on depending on your proposed load, snow is light, dry mulch is light, wet muddy rocks are HEAVY!
Remember it's not about keeping the rear tires on the ground ... It's about reducing the weight on the front axle, so it's not overloaded, which can not only increase wear & tear on it, but could cause you to tip over ?
Here are two videos ...
Filled tires?
Rear ballast needed
6,649
I don’t think you said whether the rear tires are loaded or not. I’m aware loading rear tires has zero impact on transferring weight from front axle to rear, but it does have an impact on keeping the rear axle on the ground.
455lb on the 3 point with loaded rears sounds a bit light to me, but it’s probably enough to keep the back end on the ground under most conditions. Without loaded rears, you’ll probably need more like 600lb just to keep the rear on the ground. My thought is ideally around 550 to 600lb on the three point with loaded rears to get some decent weight transfer off the front axle, more like 700 to 750lb without loaded rears.
Generally, go slow and very low when you first start. If the back feels light, you need more weight. If you haven’t run a tractor loader enough to know what “feels light”, run it in 2WD on level or near level ground. If it has any traction problems at all in 2WD on level or near level ground, it needs more weight on the 3 point. If the back end is coming off the ground you definitely need more weight on the back.
Keep the loader a few inches off the ground while you’re figuring out the appropriate ballast. If you need to raise a heavy load high for some reason (such as loading a truck) and the back end lifts, it can roll before you can do anything to prevent it. If the back end lifts with the bucket 3” off the ground, not likely much will happen other than you’ll have to remove weight from the front or add weight to the back. So your first job with the loader should be to experiment a little and get your ballast sorted.
Farm Fun
May 4, 2026
31
23
Missouri
R14 tires don't have any fluid nor any weights. My Heavy Hitch bracket will accept up to 16 weights (40 lb and/or 70 lb) so I have the option to add more weight. Plan to use either all 40 lb or primarily 40 lb with maybe 2-4 70lb.
7,646
I have 6ea rear wheel weights part #3157. I think they will bolt on your rears. Located 25 miles west of Drexel, Mo.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
52
311
53
MN
I have my 3902 tires filled with beet juice and always have medium duty 66" box blade on the rear, which is about 500 lbs. I find it keeps things pretty well balanced and digs dirt exceptionally well.
Farm Fun
May 4, 2026
31
23
Missouri
The rims for the R14 tires don't accept any wheel weights. It even surprised the dealership when they first looked at installing weights. Also tried washer fluid but the rims wouldn't hold it; major leakage.
selftot
L3400
Aug 6, 2025
116
141
Vancouver Island
I started with 500lb on my 3400 plus 75 for the quick hitch.
When i went up to 700lb it felt much more stable.
I tend to run heavy loads on the FEL. Gravel, logs, forks.
Shawn T. W
Dec 9, 2024
790
1,417
SW Missouri Ozarks
My self made ballast box weighs 707 Lbs hanging off the back of my 69 Lb Quick hitch all on my little SCUT (BX size!) ... The tractor handles VERY SIMILAR to when the backhoe is on, especially when backing and turning, and rapidly slowing down!
The BH weighs 651 Lbs, but hangs way out back ... My loader is rated at 921 Lbs at the pins ...
That size of tractor and loader, if you're planning to use it to its full capacity, I think 900 Lbs would be a good starting point besides the QH ... Unless you like rebuilding the front axle seals, or the chance of tipping over ...
I know those suitcase weights are expensive ... But 8-40's & 8-70's plus the bracket they go one would put you at 945 Lb ... The nice thing about them is if your doing lighter weight stuff, you can take a few off, plus they are the most compact weight you can get ...
nerwin
Z452KWTi-60, L2501, LA525, HLA Forks, Land Pride STB1072
Nov 13, 2024
647
1,870
Vermont
youtube.com
I have a ballast box that is 640 pounds of concrete. Works wonderfully. But I just recently bought a box blade is around 550 pounds which also works fine too. The weird thing is that with the weight of the box blade, I feel like the tractor is more stable even though its more lighter than the ballast box. All I know is that it makes a massive difference have some kind of weight behind the tires. My tires are also loaded with rim guard as well. During winter, I remove the ballast.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
125
123
Lakes Region, NH
How do your rims hold air if they can't hold washer fluid?
Farm Fun
May 4, 2026
31
23
Missouri
Good question but the installer couldn't get the R14 style rims to hold the washer fluid. Not that upset about it; don't have to deal with fluid of any type this way.
Shawn T. W
Dec 9, 2024
790
1,417
SW Missouri Ozarks
The difference of 90 Lbs is pretty close, what I think you will find is the ballast box is more compact, and the weight is closer to the rear axle, most of the weight of the box blade is the farthest from the axle, and probably farther from the axle than the back of the ballast box.
