I got fed up with repairing the ZD326 and bought a ZD1211 with a 60" deck. Today I decided to start using it. The ROPS will not go down.
My property is flat, and I have to mow under some overhanging trees, so I don't use a ROPS.
I removed the pins and the anti-rattle devices. I had to loosen the hinge bolts because they were very tight. The ROPS now moves maybe 10 degrees, and then it stops suddenly as if it has hit some kind of block.
Ideas?
Ideas?
