Here are the viscosity curves I was talking about. These are plotted as raw x/y data. which produces an exponential curve making it hard to see the entire picture in one plot.
In the first graph starting at -30C the 5W40 shows a significant improvement in viscosity at temps below-10C but above that temperature the viscosities become nearly indistinguishable. Regraphing the curve starting at 70C you can see the 5W40 actually has a slightly higher viscosity. as expected. As temperatures increase both oils continue to thin out and the curves get closer with the 5W40 remaining just a bit higher than the 10W30 all the way up to 170C
In other words the 5W40 viscosity is better at both extremes and nearly identical in the middle.
