Whilst away I had someone try and steal my mini excavator (KX36-3). They've damaged the ignition switch and the electronic housing (photo below). I can no longer start the machine - I purchased a new ignition switch with new keys and I get power to the small fuel pump and console but the engine doesn't turn over at all. I believe that there is an immobiliser on the system but I have no idea if I can simply replace the electronic housing with a new one and that will fix the issue. Any help at all would be appreciated.
