Anti-freeze treatment for wood boiler
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
388
298
NH
The property I recently purchased has an outside wood boiler which uses 400 gallons of anti-freeze instead of water. The previous owner told me I should add 1 gallon of anti-freeze treatment every 5 years to reduce electrolysis.
Anyone with a system like this have any information on what to use?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,111
1,105
E.
I have 2 biomass boilers.
can you give us the make / model and we can provide better advice?
on mine they are 100% stainless steel attached to pvc and poly pipe.
I am supposed to keep my ph level within a specific range test few times per year (by using test strips) and adding an additive package from time to time to address scale and corrosion. I think additive package every fall. Both are cheap.
imarobot
Apr 18, 2025
388
298
NH
Mine is a Central Boiler Classic CL6048 purchased in 2006. I have the test strips and additives that came with it, but the previous owner said they are only if using water, not anti-freeze.
Mine is piped with copper tubing
MapleLeafFarmer
Dec 2, 2019
1,111
1,105
E.
Mine is a Central Boiler Classic CL6048. I have the test strips an additives that came with it, but the previous owner said they are only if using water, not anti-freeze.
NAPA stocks / sells coolant ph test strips for antifreeze and my bottle calls them Gold strips.
I get my additives from Robinson Supply Plumbing which is a large / commercial plumbing shop here. Keep my ph, corrosion / scaling inhibitors within their range. I just take a sample in and they test and tell me what to do.
Most who sells / services boilers should be able to supply AND make a test for you for nothing or a small fee if your not a customer.
You've got a real top shelf boiler. keep the burn cleaned every week or three depending on use and water in spec and it will last a really long time.
3,141
1,267
Plumbing suppliers like FW Webb carry antifreeze made for heating systems.
