2150hst rear axle seals
10,770
On that model having a loader on it doesn't effect replacing the axle seal.
In fact that's one of the simplest models to change the seals on.
Pop the seal out of the case, remove the snap ring 30 pull axle and bearing, remove snap ring 40, pull bearing off axle, pull off seal, revers operation and your done.
derfrezles
B2150hst
Jun 4, 2026
Atwater, California
Thank you for confirming the The repair shop had warned could be dismantling the complete rear end. I already fixed the front axle I broke. Trying to get away from more oil on the ground than in the tractor. With age comes maintenance....
10,770
I worry about the competency of your repair shop! :oops:
