Mower Deck for BX2230
bbraniger52
BX2200
May 19, 2020
10
Kimbolton, Ohio USA
Hello All,
My BX2230 came with a RCK60B 22BX mid mount mower deck.
The deck shell is pretty well shot. A replacement shell from Kubota is little over $2100.
I'm not having much success finding a used deck shell or complete mower.
Is there any other Kubota mid mount mower that is compatible with my BX2230 tractor?
Thanks for any helpful info,
Bill
Grandad4
Apr 5, 2016
414
166
Greensboro, NC
There was also a 54 inch deck available, RCK54 22 BX
A deck for the earlier BX2200 might be a close match as the 2200 and 2230 were nearly identical. Same thing for the backhoe equipped versions (BX22 and BX23).
Depending on what you plan to mow, a simple solution might be a 3 point mounted finishing mower.
bbraniger52
BX2200
May 19, 2020
10
Kimbolton, Ohio USA
Thanks for you input.
bbraniger52
BX2200
May 19, 2020
10
Kimbolton, Ohio USA
Thanks for your input.
Bee-Positive
Nov 16, 2022
706
724
Amsterdam, NY
I guess timing is everything...keep looking and be ready to jump if the price is right.
Good luck!
