Well, I'm not going to pretend I understand all your precise and accurate information, but that was a great write-up, thank you.
I understand the top link slot vs hole explanation, makes sense. I don't have a hydraulic top link and use the slotted connection point to allow for some pivoting as the terrain slightly changes. Is that correct?
As far as the right pivoting lower link connection, I understand the need for the "float" to allow the mower to pivot up and down as needed, and the need for it.
What I still don't get is how to adjust the right lower link with the pivoting connection. Should I adjust the right lower link so that the mower pivot link is at its upper most pivot point or at the middle of its pivot, or at the bottom of its pivot? I would think adjusting this so that the pivot point is at the top point would allow both lower links to have the mower be leveled on level ground.
But now I wonder about your comments about the ability of the mower to adjust up or down when in the extended right position.
Should the right lower link be adjusted so that the pivot point is fully up in the mower non-extended position, then re-adjusted to a centered position if extending the mower to the right?
I hope you understand my questions, after reading this, I'm not sure I do but hope you do
