Worked on a lot of diesels but not many Kubota's
This tractor came to me with cold hard starting complaint
Customer purchased this tractor with only a few hundred hours on it many years ago
Says it has always been a hard starter, requiring glow plugs even on hot summer days
Now it's really bad
At his farm, outside 30 degrees it will crank good and kind of start but then peters out
Keep cycling the glow plugs and retry and after maybe 10 tries it will stay running but is struggling
Mostly black smoke and when it finally starts it clears up quickly
When running fuel lines 1 and 6 made very little change and very little fuel would squirt out
1 and 6 exhaust manifold would take a long time to even begin warming (no smoke)
2 thru 4 are hot quickly
Customer had it at another shop and they claim they installed new rings, rebuilt head, new injectors, and new glow plugs. Checked timing and compression all good
But NO better and maybe worse
When I got it to my shop, I found 1 bad glow plug and low voltage 9.5v at glow plugs
Bypassed the wiring to glow plugs and now 11.5 at glow plugs but still no change in starting
Checked fuel pressure 3psi and installed new filter and still no change
Checked air intake and removed intake hose to be sure and still no change
Pulled injection pump and found signs of water/rust on plungers
Purchased a reman pump
Original Pump had 5 shims and I left one out leaving 4
Still hard starting cold but runs much better and with the exhaust manifold off all ports are hot and even
Found that 1 and 6 had compression leaking around injectors so I pulled them and ran a compression test 250-275 psi. put air pressure on them and found intake and exhaust valves leaking.
Pulled the head found valves did not look like a rebuild and valve recession was .075
Took head to my guy and installed new seats, ground the valve slightly with valve recession now at .048
Installed head and checked piston to head clearance .053 with only the gasket, no shims.
Still hard starting but runs much better
When starting I am cycling the glow plugs and it will try to start rather quickly
Each cylinder will have heavy black smoke while cranking and when it kind of starts it only runs for a few revolutions and peters out
Acts like a gas engine when the choke is left on full after start
Checked timing and looks like it's about 18 and should be 25
Pulled all shims and when bolting the pump back on the rack would bind up so I installed 1 shim and still bound up, installed another shim for a total of 2 and rack is free.
When bound up the rack itself would move just enough to know it must internal problem causing binding
Appears the plungers are being pushed up to far with no shims, is this normal?
Its hard to believe the timing gears are off because customer says the front cover has never been off and I do not see signs of removal
Taking the injectors in tomorrow for testing
Any ideas?
Now it's really bad
Any ideas?
