3. I have turf tires on my B7100. Keep in mind, it is a lightweight tractor, without 4wd, so that may influence my experience. I do a lot of work on lawns, and they leave little to no marks. I also do a lot of work with a rear blade on gravel - for the most part, I have no issues here either, but if I am cutting deep I may occasionally break traction with one tire. Usually correctable by diff lock or gently applying one brake. However, in dirt, particularly mud, I would not recommend. Lower pressure does help some with this, but at the cost of a softer tire when carrying weight. If I were in your case, doing more FEL/backhoe work, I might stick with an R4 for the stiffer sidewall. In my case, I'm quite fond of my turfs.
