Need help with replacing speakers
MatritKlutz
Alpharetta
I have a M8200 with a cab. I think it's about a 2000 or 99 year model. The speakers have never been replaced. I tried to remove the speakers today but cant get the screws to come out. They just spin and spin. I looked it up and it says its because there is a nut of the back side of the headliner that has come loose. Is there anyway to get these out without removing the top of the cab?
Hugo Habicht
G1900
Jun 24, 2024
1,439
2,025
Ireland
What you can try in this case is pulling up the speaker while turning the screws, so that the nut gets some friction against the panel. But this will only work if the nut was put in without any threadlocker.
Hugo Habicht
G1900
Jun 24, 2024
1,439
2,025
Ireland
might, fingers crossed, get them off but then HOW do you remount them !
He did not ask that question, did he? :)
I would put rivet nuts into the holes. I am actually surprised that they used nuts for holding the speakers, this would not be common practise in industry.
Is it possible that they are plastic rivets pushed it? I've seen them with a philips head for the centre pin to get out. They turn very quickly without coming out. In this case you have to stop the rivet from turning.
Mark_BX25D
Bx25D
Jul 19, 2020
2,062
1,582
That's what I was wondering, Hugo. Probably not for speakers, though, but it should be checked out.
I've often used a small pry bar to put some pressure on something, as you suggested in post #3.
If that doesn't work, there's always C4. :D
11,337
Another option would be to grind off the head of the screw using a Dremel if it's recessed, or a Fein Multitool (or similar) with the appropriate blade if the head of the screw is exposed.
I agree with @Hugo Habicht re nutserts or rivet nuts or whatever you want to call them, assuming the material is strong enough to support them. They're hard to beat in sheet metal. I bought a nut rivet tool years ago and when you need it, you need it.
