BX23S Capabilities
RTG
9
Adel, GA
New to the forum. I'm considering buying a BX23S. I need a small tractor for dirt moving but also have a lot of pine stumps up to about 10 inches in diameter I need to dig up. Will the BX23S backhoe handle that? Thx for any help.
PaulL
B2601, MX5200.
Jul 17, 2017
2,743
1,748
NZ
How many is "a lot"? Is it plausible to rent a machine to do them all in a couple days, then buy a BX without a backhoe? Do you have other tasks for the backhoe?
I haven't had a BX backhoe, but I have had a small mini-ex, which most people will say is more capable than the BX. It can dig stumps, but it's very slow going. I'd do it for a couple, but I'd get pretty tired of it if there were a lot. A bigger machine will do them dramatically faster - instead of carefully working around the stump breaking the roots one by one, then slowly rolling it out, you can just put the bucket on the stump and pull.
If you're looking for a weekend hobby for a few years, then yes. If you just need the job done, I'd seriously consider renting a bigger machine (or hiring a guy with a machine who does it all for you in one go).
Scm
BX23S
Sep 28, 2024
319
310
Missouri
Its doable depending on how much time you have. It took me about 8-10 hours to get a 14"-16" ish white oak stump out with my BX
3,014
It will do ANYTHING you want it to!! However - a mans gotta know his limitations! ( Clint Eastwood)
It will do it a small bite at a time !
I have removed many stumps - depending on tree type it will be fine, make sure you have a sawsall or other root cutting device.
I am of the opinion that it is better to buy once - cry once than to rent several times!
edritchey
2026 Kubota T2290-48 2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75
Jul 19, 2014
1,172
918
Wellsville, PA
Those little machines are amazing.
RTG
9
Adel, GA
Thanks for the info. I probably have about 50 pines that I'll be cutting down. Most of them are in the 4"-6" diameter, but a few are closer to 10". I just bought a property where a pond was dug years ago and the dirt piled in three places. Over time, the pines grew up in the dirt piles. I want to get the pines out and use the dirt for a little fill and grading in a few low spots. I'm not looking for a quick weekend completion. This will be an ongoing project.
RTG
9
Adel, GA
Thanks for the reply and the tip.
Scm
BX23S
Sep 28, 2024
319
310
Missouri
Pines have shallow roots. If you cut them tall 5-6-7' up (leverage), you may be able to pull them out of the ground using the backhoe. maybe a footish off the base of the stump you could dig around too break some roots, maybe a bucket deep, then use the bucket on top and shake the tree to break more deeper roots
RTG
9
Adel, GA
That sounds like a good plan. Thx
6,209
Yes it will be 'fine', not fast but it WILL do the job. Have removed 1/2 dozen spruces 18-24" diameter last year. Yes slow, but I wasn't in a hurry. If you need speed, rent a full size excavator for the day. Two tricks, cut tree but leave 2-3 feet of the trunk, makes a great 'lever' to wiggle loose the stump. Also dig 3-6 feet from the trunk, depending on the type of tree, so you can cut the roots. They will make it a LOT easier to dig and wiggle the stump out. If all your trees are the same species, you'll figure out in the first 2-3 how best to attack the rest of them. Also be sure to grease all the Zerks before you start !
Shawn T. W
Dec 9, 2024
630
1,150
SW Missouri Ozarks
That is the same size SCUT that I have ... These are the only stumps I've dug out ... Some kind of hardwood ... The factory 12" bucket would only scratch the surface of the frozen ground, so would the 6" trenching bucket ...
Ground was frozen 8" down, I used the root ripper to break through so I could dig, a very handy tool for a Backhoe! It really concentrates the limited power you have into a very small area!
The "Quick-On" makes swapping tool ends very quick and easy ... All available from https://www.bxpanded.com/bx23s lots of very useful additions to your tractor!
The"Quick-On" basically works like this ... You install it with your factory pins, and then you take the red pin and slide it into the red slot, then hinge the purple up and put in the pin! The website has a short video if it's operating ...
Speed25
L2501(sold) - BX25D
Apr 23, 2024
300
475
NC
This method has worked well for me on hardwoods (no pines near me). The extra leverage of the tall "stump" really helped to free the roots.
RTG
9
Adel, GA
Thanks very much for the info. My ground is very sandy in South Georgia and is always soft. I have no hardwood stumps to pull, all pine. The backhoe bucket should dig without a problem.
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
170
79
Danville
Totally agree with the suggestion of the root ripper and quick attach from BXPANDED. I have a BX23s and the backhoe will drag the machine. Power may not be as much an issue of the size of the machine. Love my BX for my 3 acres, I can think of worse ways to spend a few hours than sitting on a machine digging stumps!
bird dogger
Vendor Member
Feb 24, 2019
1,763
1,745
North Dakota
I have the same quick-on and root ripper for my BH77 and couldn't imagine getting by without it. It turns the backhoe into a mean digging machine for removing brush, stumps, and other debris hiding in the ground!!
Shawn T. W
Dec 9, 2024
630
1,150
SW Missouri Ozarks
You're welcome!
I still think the ripper is a great tool, you may do just fine with the factory bucket, but I think the ripper which is only 1" wide will put a LOT more force on a stubborn root, and break it more readily!
I have the opposite type of soil, some days I think I have more (small) rocks than dirt! 😂
While I don't have a BX, I think I have every accessory they make to fit on my Massey Ferguson ... Piranha Tooth Bar, Thumb, Quick-On, Trenching Bucket, Root Ripper, 2" receiver hitch "Trailer Mover" that while I've had that last one for over two years, I only used it to move a trailer two days ago! Bxpanded has lots of ways to spend our money, but they are all designed and built in the USA!
Fence stretcher!
Scm
BX23S
Sep 28, 2024
319
310
Missouri
I tried rock raking my pasture only to make more rocks. Best method I found was to wait for the one or two days of freezing temps we get and use my bucket to scrape the rocks of the top.
5,920
You might want to check with someone local on how the root system of the pines are in your area. Where I am, in central NC with clay soil, the pines are shallow rooted. In the sandy soil of eastern NC where my brother lives, the exact same species of pine will have tap roots that start out about the same size as the trunk of the tree and go down several feet. So my Short Leaf Pines wouldn’t be hard to dig out a little at a time. His Short Leaf Pines, not so much.
