My first time for this, hope I'm doing it right. I have to jiggle my shifting lever back and forth to find the only spot where the engine will start. I don't know where the switch is or what to look for. Any suggestions would be appreciated.
Thanks exactly what I needed to see. I do interpret the range switch as the neutral but now I know the correct name.There isn't one on that model.
There is a clutch switch, and range switch, and a PTO switch, that's it.
I guess you could interpret the range switch to be a neutral switch.
