Another small but functional boat upgrade!
10,827
If you've ever owned a small boat you'll know that storage can be a problem. I wanted to get a little more storage as well as gain better access to the inside of the hull for inspection purposes. I recently bought a Klein Tools camera that connects to my phone and wasn't able to snake it into some areas so figured this access door would help.
It's felt like spring here so I took the chance yesterday to stop by the boat storage facility and check another upgrade off the list, well almost. I'll need to use some 5200 to seal the door to the fiberglass and buy some stainless steel machine screws to finish the installation of the access door, but the hard work is done.
I learned recently that boats over 20 feet in length don't need flotation foam in the hull so it makes sense why this Robalo is 20 ft and 7 inches long!
Here's the before photo showing the location of the new access door. It's in the bow area and directly below the small square shaped seat cushion.
Reactions: 7 users
10,305
Sweet upgrade:
With as little of snow as we have gotten, I worry about the state of the lakes this coming season! :confused:
bird dogger
Vendor Member
Feb 24, 2019
1,761
1,742
North Dakota
And here I thought you were next going to show us your home made door & casing mold. Then laying up the new parts with fiberglass matting and gel coat!! :ROFLMAO: Or maybe you just left those pics out???:ROFLMAO:
Hugo Habicht
G1900
Jun 24, 2024
1,289
1,858
Ireland
I was expecting the same. Was that not done with the instrument panel?
Doesn't matter, great result, well done ! (y)
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
95
80
duluth mn
From one Boataholic to another Looks great, good work!
As owning many boats (lost count after about 6) there is never enough storage until you get to over 40ft, then it might be iffy.
Don
10,827
Yep. I created a custom center console arrangement last year and it was a brutal and stressful job for a fiberglass novice. The problem was the lack of a large enough flat surface on which to mount the new electronics so I had to build up the center section with sheets of CSM and biaxial fiberglass. In hindsight it would have been easier to buy a large piece of acrylic, but what you find with mass produced boats is that a lot of corners are cut and the attention to detail isn't very good. I was able to address other issues that really annoyed me, for instance, the cut out for the binnacle was a disgrace, but I rebuilt the area and upgraded the binnacle and now it's how it should have been from the factory.
I have some other upgrades to complete, but I can take care of them incrementally, and not lose two months of boating time as I did last summer.
From this ....
... to this. :)
Reactions: 6 users
10,827
Sweet upgrade:
Flathead Lake and the Flathead River are full right now due to so much rain this winter. It should be ok as long as the water isn't allowed to flow out through the dam.
Old Machinist
Kubota LX3310 cab, JD4410, JD F725, Swisher 60", etc.
May 27, 2024
624
736
NE FL
Nice hatch install!
I bought one of those Klein Tools cameras that connects to a phone a few years back. At the time they didn't have the app for it on the play store and after downloading it from the Klein web site I couldn't get the camera to work on my phone so I returned it. I have tried a couple of the cheap ones that do work on my phone but they don't seem to have a usable image for what I tried them on.
10,827
Nice hatch install!
I'm still figuring out the Klein camera but it seems to work well with my phone. There's a knack to getting good images I'm sure, and you have to know what you're looking at or want to look at, but I managed to get this view of the inside of the hull. Hopefully I'll be able to get better images as I figure this camera out. I can take video too so that might be the better option.
7,195
My daughter and SIL are always working on their hobby fishing boat.
Storage is always a concern. Good job on your project.
Boats make a lot of folks happy.
Out on the Pacific.
