I was concerned my clutch had failed but I removed the inspection cover and had a look at the shaft that connects the transmission to the HST. When I let off the clutch pedal this shaft spins but it cannot turn the HST shaft because the coupler is stripped out on it.
it looks like it could have gone back another 3/4 inch or so, so did it slip off somehow? Assuming I can’t save the splines on the HST shaft, is this something I can purchase and take apart the HST to replace or is it toast? How bad of an idea would it be just to weld the coupler to the shaft?
Does the case have to be split to get this coupler and intermediate shaft out or is is serviceable from the bottom?
The power steering and lift is working but the tractor won’t drive.
