Cannot get stuck heat seal out ... need advice or ideas
Ursa Minor Beta
Beta Marine 25 ( Kubota D1005 )
Aug 31, 2025
17
The deep ocean
Hello,
as a followup to my previous thread about my Kubota d1005/Beta Marine 28 engine not starting properly I decided to replace the injectors.
And to do so I needed to remove the heat seals.
To do that I used a left-hand extractor tool which worked very nicely on two of the seals but of course the one last from the third cylinder ( closest to the exhaust ) did not move one bit. Instead the extractor just made the bottom opening of the seal larger. Now I wonder what options I still have except removing the cylinder head and trying to poke it out from the inside. ( this option would of course only be the very last resort as it could create even bigger issues if something goes wrong.
I could of course take a slim key file and try to split the seal to remove it but that feels like it could create collateral damage ...
Any ideas most welcome!
Thanks
9,200
Hook tool for a slide hammer?
Ursa Minor Beta
Aug 31, 2025
17
The deep ocean
I dont have access to such a tool where I am at the moment.
Currently I am wondering if I should give up for now and just install the injector with a copper washer on the stuck heat seal and deal with the whole situation once I have access to a proper workshop.
What would that do to the new injector?
I guess it would work for some time, no?
9,200
With the heat shield damaged it could make the injector lock up and destroy it.
It could even damage the engine if it sticks open and floods the cylinder with fuel.
Ursa Minor Beta
Aug 31, 2025
17
The deep ocean
I see... Well the engine would supposedly only run for a couple of hours before I could reach a proper workshop.
Can damage to the injector occur even on a short run?
I'd of course feel much better with a proper repair but it seems a bit out of reach here.
9,200
Yes it could happen within minutes.
it might or might not.
If it were mine I would run an old injector in it till you can get it fixed properly.
Ursa Minor Beta
Aug 31, 2025
17
The deep ocean
Thanks again.
I am trying to understand what might happen with the damaged heat seal.
From what I understand this cup is protecting the injector end from the combustion heat, right?
As there is an additional copper washer, I guess this is doing the sealing against the pressure inside the chamber?
Now with a damaged seal the injector will get too hot and seize/break/burn so letting either no diesel in or too much?
Is this correct?
Ursa Minor Beta
Aug 31, 2025
17
The deep ocean
With two more days of patient knocking with a home built pull hammer, heat and penetrating oil it did come out after all ...
3,640
‘Nothing in this world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent.” —Calvin Coolidge
9,200
Thanks again.
Is this correct?
Glad you finally did get it out,.
Yes you are exactly right on what could happen to the injector with a damaged / missing heat shield.
