B670 before and after photos
Seemtns
B7100
Jan 8, 2016
12
NH
I picked up this B670 backhoe from a member here for 2k, and worked through last winter to restore it, late spring and about 2k later it's on the B7100. It's truly amazing how muck power this backhoe has. A great old girl that keeps on digging! The rock in front of the loader was it's first project, and it's plucked out bigger ones!
3,099
Nice job, looks very clean. Interesting mounting plate- looks like it mounts the hoe a little further back than the stock mount?
Seemtns
B7100
Jan 8, 2016
12
NH
The back mount plates are where it is originally mounted in line with the front attachment bars. The hole idea of the hook on the back plates is to back the tractor in with the loader bucket lifting the front end up which hooks the back hoe on, and as I lower the front end it lifts it into place allowing the front arms to slide over the mounted bolts, all I have to do is put a lock washer and nut on, hook up the pump and away I go. Pretty slick way of mounting the hoe.
3,099
Very slick- too bad you weren't an engineer at Aeroquip when they built these little backhoes.
areal98
Kubota B7100
Jul 11, 2025
Maine
This is kinda a shot in in the dark being and old forum.. but do you still have
Do you still have the dimensions to those rear plates that you fabricated?
old and tired
L2800 HST; 2005; R4
Sometimes, people have an email address connected to their profile, he was
Last seen about a year ago, on Jun 23, 2024
If you click on his name or photo, menu opens, at the bottom, "Start a conversation" still a long shot but costs nothing to try!!!
areal98
Kubota B7100
Jul 11, 2025
Maine
Good thinking thank you, I just started a thread so we’ll see if I get any luck
