RTV520 leveling attachment
kenn23
RTV520 Z422
Jul 9, 2025
Arizona
Hello, i recently purchased a RTV520 that came with a 2 inch hitch. i have 6 acre's and some of it has some bumps that i would like to level out with the rest of the yard so it is not so bumpy when i use my Z422 zero turn. I am having trouble finding anything that can be attached to the 2 inch hitch. Does anyone have any recommendations of something they might have used?
Thanks
Sidekick
Jul 29, 2023
997
1,335
N.Y,
I haven't used any of them but have seen that a company called DR has tillers and scrapers that can be towed behind an atv with a trailer hitch. Check the capacity for your hitch in the manual before hooking equipment like that to it.
Bee-Positive
Nov 16, 2022
263
258
Amsterdam, NY
Depends on how you're planning on "leveling" the land. You can bring in dirt or sand and level it or you can till it and level it. There are many options for a tow-behind attachments but as you say they typically do not have 2" receivers. Go to drpower.com type in "tow" in the search bar, they have tow ball kits that might work.
Bee-Positive
Nov 16, 2022
263
258
Amsterdam, NY
Does your ATV have a receiver hitch? If so you can get one of these Clevis Trailer Pin Mounts.
If not can you just unbolt the ball and use a Pin through the existing hole? Would be a PITA if you changed from one to the other very often but it may be a cheap option.
kenn23
RTV520 Z422
Jul 9, 2025
Arizona
Hello, thanks for the replies. i will look at some of the recommendations. to answer some of the questions,
What i need it for is to smooth out area's where the ground might be higher the the surrounding area. most are tracks left over by large trucks during the building process.
It has a standard 2 inch hitch where i can put anything into it with a pin to secure it. just like a car.
