Plastic, stackable pallets?
Mustard Tiger
BX23S
Jun 26, 2025
78
154
Pacific Northwest
There are tons of free wood pallets in my area, but also found a guy selling these plastic, stackable pallets that are similar to what I have pictured below. HE wants $15 each, and would take $50 for four of them.
Wondering the pros and cons of wood vs plastic? Plastic will surely last longer. Was thinking of picking a few up to sit my attachments onto when they're not in use, to use with the front forks when transporting something that needs a flat base, etc.
Old Machinist
May 27, 2024
428
462
NE FL
I've considered those but never looked into how thick and sturdy they are. I have mine on concrete blocks.
Wooden pallets disintegrate and leave nails and staples on the ground.
Shawn T. W
Dec 9, 2024
248
406
SW Missouri Ozarks
I don't think they will hold up to attachments very well, they will flex too much and then crack ...
There are plastic pallets that are built more like a traditional wood pallet ... Kinda hard to see, this is a small one I got that's only 36" square, trying to save weight on my forks ...
I use wood, because they are free, and they are used in my barn, for attachment storage
5,741
I've always 'doubled up' on wooden skids. top one holds the goods, lower one the water and bugs eventually get. makes it easier to get the top skid, forks stay 'high and dry'.
Youbet
Kubota M5-111
Sep 1, 2022
Kentucky
I use a heavier duty ones that I found on my wife’s FB marketplace. I think you can find them a little cheaper also. Great for firewood.
Sawburner
L2501, Gravely 526
Dec 18, 2022
77
214
NY
I have some of the heavy built ones and they work good for attachments. I got mine from under bulk coal bags, find some body that burns coal and maybe you could get them free or cheap. Ask where they sell coal maybe they could ask there customers about contacting you.
L35
Jun 13, 2010
588
559
CT
I use them for firewood for a long time now, uneven terrain and stack 5’ high worth of hardwood on them with no issue. I also have implements on a few of them like snow plow and York rake. I switched out of wood as I came across more, now fully plastic. Mine were from the usps I found them on marketplace for $5
Hoserman
Aug 1, 2022
206
321
Grayling, MI.
Thats a good idea. I have a couple things that would be a lot better sitting on one of those pallets than just sitting on the ground. Especially my three-point carryall deck.
Old Machinist
May 27, 2024
428
462
NE FL
Concrete blocks are only a couple bucks apiece and last forever. 3 or 4 is all you need for each implement.
Shawn T. W
Dec 9, 2024
248
406
SW Missouri Ozarks
Yup! And easier to move than cement blocks! (If you have forks!) This is the 36" I have ... Used by beverage companies ...
