B2920 no crank issue experience solved
507 rzr
B2920 and ZD326
Jul 1, 2025
Illinois
I am new here but thought I would share my experience as it might help someone in the future. I have a B2920 and really not much experience working on tractors. I had a no crank issue that happened. I found every safety switch that i could and checked them for voltage coming out of the switch. All appeared good. Next I jumped across the starter to start it to ensure battery was good. Some or all of you may know this but there is an OPC controller on the machine that appears to receive voltage from those said safety sensors. It acts as a switch to continue the flow of electricity to the starter from the ignition switch when it is "happy" by receiving voltage from all of the sensors. I was able to test each switch at this controller instead of going to each individual sensor. Once I found the wire with no voltage, with a wiring diagram, was able to trace it back to the voltage regulator. It sure makes it easier to test those sensors all from 1 place. I replaced the voltage regulator and it fixed the issue of no crank. Looking back I also realized that my battery light was always on at low idle and now that is fixed as well. Again, Maybe this is all common knowledge to everyone , but I didn't find this information readily available. For all I know it was just a fluke that I found it, but it worked for me. Hope this helps someone as I'm sure that my tractor is not the only one to ever have this type of issue.
Reactions: 8 users
Blue2Orange
Apr 3, 2025
140
64
Bayview Township
Thanks. Bit clueless regarding modern tractors with all their electrical switches and relays.
Bee-Positive
Nov 16, 2022
303
299
Amsterdam, NY
Welcome aboard 507.
You may be new to tractors but that's a fine bit of diagnostic detective work you did there. You must have mechanical aptitude from somewhere. You'll fit right in here. ;)
jaxs
B1750HST
Jun 22, 2023
932
712
Welcome to OTT 507, it was very thoughtful of you to share your experience.
