I purchased this tractor about 3 weeks ago and finally got her home last weekend. Mostly in very good condition for sitting outside unused for the last couple years. Like so many of these it was replaced with a newer and bigger tractor and left forgotten on the edge of the property watching the world go by. Last weekend whil browsing localities within driving range I found a B219 loader nearly complete in excellent condition. Secured the deal and picked it up yesterday. A 780 mile round trip. I drained the old fuel and replaced the fuel filter. With a little bit of coaxing I had the engine running and idling smooth. I'll be changing all fluids and filters very soon. Ordered new tires all around. Increased the width on front and rear by a few inches but diameter is pretty much stock. My list is as follows and subject to change several times before I'm finished to be sure!
1. Remove old tires and clean up wheels with sandblaster. Prime and paint wheels inside and out. Mount new tires and have ready to reinstall onto tractor.
2. Remove fenders and tread for better access to sides of tractor for making a cardboard template for subframe pieces. Will use 3/8" plate steel for side pieces. 3x5" rectangle tube will tie into these plates to provide main mast support at the rear of the loader which should be adjacent or just ahead of the steering wheel. A gusset style support coming off the top of the 3x5" will have a plated face to bolt onto the side of the tractor near the bell housing/transmission area. Heavy wall tube style supports will extend from the rear masts to the front corners of the frame on the tractor tying into the subframe plates. (I haven't really done anything outside the Kubota design I see from pictures of other tractors with this same loader. No need to reinvent the wheel in my opinion.)
I will post photos along the way as I make progress. I'm grateful for any and all contributions of ideas or information
that will provide assistance with this. Maybe my experience here will be helpful for someone else to restore their tractor and add their own loader or other implement.
Thanks for reading.
Thanks for reading.
