g_man
Feb 3, 2023
242
1,101
NE Vermont
I did go with a dead blow hammer (it’s orange and won’t rust) and did some serious work with it to get the tab into the arm.
I have a 5' bar and find it a huge help for inching implements around into alignment.
gg
JonM
Kubota Grand L6060
Nov 29, 2024
84
154
wisconsin
all i did today with the tractor was empty the horse poop out of the bucket from last nite and bring the horse water troughs for a clean and refilled them with the 275gallon water tank carried by the kubots
BBFarmer
Jul 12, 2024
624
1,239
Terry, MS
The best solution for attaching implements is to have one tractor for each implement!
This is true.
Most of my neighbors have multiple tractors for that very reason. One will stay on driveway duty, other might mow.
I got to experience this for a little over a year or so. Then sold our first ole girl to one of said neighbors.
nerwin
Nov 13, 2024
539
1,331
Vermont
youtube.com
Sorry I been MIA. Just haven't done any tractor stuff lately.
My neighbor's dogs dug a massive cavern under the stone patio and asked me to fill it in. A couple years ago she asked me to dig up a pile of dirt that was left from previous owner making it difficult to mow. So I used the material from here to fill in under the patio and I needed fill so I took the rest haha.
I got it seeded and used what little straw I had left haha. It was a job on a budget so I didn't get too fancy.
I also smoothed out the area in front of the garage too. I'm gonna be digging it up and replacing the base as it's getting muddy sometimes but this looks better for now. I wanted to do it now before it got dry, much better when it rained recently for doing driveway work!
Anyways that was my day. I have to say it was a pretty good day. Some sun shine, not too hot. But any day is a good when you're sitting on the tractor doing some work and making noise in the neighborhood 😁
Reactions: 9 users
8,811
Who wouldn't want five, ten or even twenty tractors, but two tractors is certainly a good start and makes life a lot easier. I never underestimate the value of convenience. In my small world, there's a tendency to use something more often when it's easier to do so.
As an example, before I ran 220V power to the garage, I used to wrestle with the clothes dryer to gain access to the outlet behind it, run an extension from the dryer oulet through a window and out to the garage, and connect a second extension in order to do any welding or plasma work. Once done I had to reverse that process. It was such a pain that I'd tend to wait until enough work piled up to make the hassle worthwhile.
After I trenched from the house to the garage, installed conduit, ran 6-gauge wire, installed a breaker box and outlets, I now leave the welders plugged in and a 30 second welding job doesn't get put off. I find that I do a lot more welding these days and enjoy it more since it's not an Olympic event getting power to the garage. Yep, the power of convenience! (pun intended).
Reactions: 6 users
GrumpyFarmer
4,036
I agree with the snarky guy on this forum that recommends a pair and a spare for tractors and EDC😉.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,382
3,227
PEI Canada
Best shovel I've ever owned.
Planted a pair of dwarf cherry trees.
Reactions: 8 users
Moose7060
Oct 14, 2023
827
2,243
bc
He hasn't been on here much. Maybe he is finally using them?
nerwin
Nov 13, 2024
539
1,331
Vermont
youtube.com
Picked up the new washer tonight at Best Buy.
I put the pallet forks on and used a plastic pallet, butt it up against the tailgate on the truck with just a slight angle so I can slide it right off the truck and it worked perfectly. Then I brought it to my basement door and leveled the pallet out with the same level as the threshold so I could slide it right into the house. If I had a hand truck it would've been even easier.
Work smarter not harder they say 😁
Definitely a lot more easier than doing it by hand. Last time it was a pain in the butt. They're just so awkward to move.
Reactions: 7 users
DenmanBC
Pending purchase
Aug 6, 2024
29
14
Coastal BC, Canada
Outstanding and thank you @RCW
My Kubota guy brought a quick hitch over for me to try. I was attaching a Nolts Raised Bed Layer to my L3302. This was frustrating as my plan had been to run the hopper over the field for fertilizer and pest control, then start running the beds. After all of the time it took to hitch up just to move it, it is hitched and going to stay there until all of the rows are laid. Then I will try this LP quick hitch (which I must say is pretty impressive). I have very few implements at this time but most are PTO but my research seems to indicate it can be a little bit of extra work to use the QH and PTO but not impossible and might be less of an issue using a PTO extender.
I'm getting ready to order an L3302 or L3902 and am putting together my purchase list and "wish list". Not sure which list the quick hitch should go on. Sounds like a useful addition but not sure if it is justified at this point. I will mostly be switching between a rotary cutter and box blade on the rear PTO.
6,917
Like anything, there will be some that swear by a QH, and others that won't deal with them.
Either position is fine with me.
I bought my QH for $80 many years ago from Harbor Freight. Looked remarkedly familiar to several other "brand" models they wanted $3-400 for...... :unsure:
If buying new implements, many are now QH compliant. However, some are not and something to look into. Older implements likely may not be, but often can be modified to fit.
If you now have PTO-driven implements, the QH lengthens the needed PTO shaft length 3-4". Depending on the length of the current PTO shaft, that may/may not be problematic.
Many of the QH's have hooks that are Category 3 in size (large diameter). Your implements will likely have Cat 1 pins (smaller diameter). May require use of a bushing on the pin to properly fit the QH hook. Bushings can be had for a few dollars. I have bushings on all the pins I want them on.
Some pins I don't bother, as they don't need the connection to be "tight." Good example is a Carry-All I use all summer. All I do with it is lift. Doesn't need bushings.
My Box Blade does have bushings, as it engages the ground and has much more torque on it.
Can easily make them if so inclined.
DenmanBC
Pending purchase
Aug 6, 2024
29
14
Coastal BC, Canada
Good info. Thanks
S-G-R
Jun 17, 2020
1,382
3,227
PEI Canada
Greased the SA10 PHD and took it of for the bucket. Was going to use the loader to lift the mower to clean the deck and swap the blades. So far, the weather isn't cooperating.
Reactions: 7 users
nerwin
Nov 13, 2024
539
1,331
Vermont
youtube.com
So I got the new washing machine installed today..only took 8 hours. Problem after problem but got it finished. The washing machine has Wi-Fi and smart home connectivity and I named it Kubota because it's a front loader 🤣🤣
Reactions: 8 users
Bearcatrp
Mar 28, 2023
880
515
Minnesota
after finishing this project last week, been using the bucket to rake crap up to dump out in the field. Then put the forks back on, put on a pallet, then went around trimming trees. Can get 4 feet higher to cut branches. I bring a ladder to use to get up on the pallet. Works pretty slick.
Hugo Habicht
G1900
Jun 24, 2024
658
865
Ireland
8 hours? Wow ...
Since you named it Kubota: when will you spray it orange?
Moose7060
Oct 14, 2023
827
2,243
bc
I called my dishwasher Kubota once. Won't make that mistake again. She slaps really hard!
Reactions: 10 users
MotoBBQ
L3902 w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
31
177
MN
Mowing season in full swing here.
Reminder to watch out for these little guys! Mom kept a close eye on me just about the whole time I was mowing.
Reactions: 17 users
