Bx23 dual wheel setup?
2,838
Never seen it before - WHAT are you trying to achieve?
2" Spacers will make a hellva difference
Bearcatrp
Mar 28, 2023
875
514
Minnesota
My BX1880 manual states not made for dual rear wheels. As posted above, spacers is what you should look at.
b454rat
B7100HST B6100
Dec 10, 2022
36
Windsor NY
Put some fat tires on it. I put 12.5 ags on mine, and my back yard is a friggin' swamp rite now, barely got above the wrap around tread on the sidewall, and, hardly spun a tire.
armylifer
Mar 26, 2013
2,147
920
Thurston County, WA
You would be able to mitigate some of the damage by putting tubes in all your tires and lowering the air pressure in all tires. This would make the tires float over wet ground easier. The reason to put tubes in the tires is because if you lower the tire pressure too low without tubes in them you run the risk of running the tires off the bead. With tubes in the tires you can run much lower air pressure without a high risk of running the bead off the rim.
3,223
For those that do not read the thread I referenced...a cut and post from Post #29
"I have a Kubota BX25 and I have a set of duals on the back and on the front not for being tippy but for floatation I run mine through a lot of swampy ground with a 4 foot brush hog and anyone with a BX knows they are useless in any real mud because of ground clearence there is no clearence but with the front and back duals it floats on top and works great I have been 5+ years on duals without a single issue and have mowed hundreds of swamp acres no one else seems to want to touch..."
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
192
194
upstate, NY USA
This BX dually topic was discussed here in February.
Pictures, YouTube video, parts availability.
