While I have no specific data on tip over angles, I will throw out this, for what it is worth.
In my rock crawler days, dashboard inclinometers were just becoming popular.
Everybody bought one and proceeded to test their roll angles, under controlled conditions- using jacks, ramps, and such in driveways & parking lots, to find that magic tip over point.
Everyone made note of those angles, and headed for the field to test the new data.
And promptly had more rollovers than they had before the inclinometers.
Further testing revealed that the smallest things could have tremendous effect on that roll angle.
A tiny undetected dip on the low side, or a similar bump on the high side; as little as a 3lb difference in tire pressures; fuel shifting in the tank; an ice chest or a passenger shifting position; carrying a different cargo layout from the test conditions, etc..
The inclinometers became a rough reference, sort of a talking point for after an obstacle- "Wow, my inclinometer read about 35 degrees, and I didn't roll!"
They eventually fell out of favor altogether.
Point being, if you get a number for that tip over point, use it as a rough guide, rather than a hard & fast value.
YMMV.
