Quick Hitch for L3902, W68 Chipper and FM-62 Flair
ben_2000
17
San Francisco
So I spent 2h trying to attach my Chipper to my tractor for the first time, I guess it will get quicker but it was not fun or easy.
So this leads me to getting a quick hitch and making my life easier but I am now confused in the middle of Cat 1, 2 etc etc
I think SpeeCo E-Hitch Cat 1 is the right thing to get. Can anyone confirm? or suggest something else.
https://www.goodworkstractors.com/product/category-1-e-hitch-quick-hitch/
Thanks
Ben
MOOTS
MX6000
Jun 27, 2019
2,157
2,670
Canton, Georgia
Are both implements quick hitch compatible? If not, I’ll suggest a set of Pats quick attach. I have them and it is much easier to hook up without being confined to QH compatible implements. Also it is easy to hook up the PTO, then attach the top link.
4,846
I’m not at all trying to talk you out of a quick hitch.
I don’t have a quick hitch. Hooking up the WC68, all but one time I’ve been in a shop with a smooth concrete floor and the chipper on a dolly with swivel casters on all four corners. With the tractor turned off, hook up the PTO shaft first with the chipper back a bit and canted off to one side enough to allow room to get at least the upper part of your body in between the tractor and chipper. Then roll the chipper to hook up the left lift arm (the one without the tilt adjustment). Next roll it to hook up the right lift arm. Finally, hook up the top link. That method allows me to hook it up in 5 minutes or less (now that I’ve had a good bit of practice). BTW, the bottom of the steel shipping crate/pallet makes a swell dolly if you bolt on some casters.
If you are hooking it up on dirt or some other uneven surface where you can’t roll it by hand on a dolly, it’s a bit of a trick getting it on but practice should cut the 2 hours dramatically and I would think a quick hitch would help. I’ve done it once when I was away from home with it and it took me and a helper about 10 minutes, mostly because the splines on the PTO shaft refused to line up. Don’t know how long it would have taken if I was alone, but I know it would have been a lot longer.
To me, the problem is if you don’t hook up the PTO before putting it on the 3 point there’s not enough room for a full grown man to get in there to hook up the PTO. If you leave it back too far, you’ll pull the PTO shaft apart when you slide it out to hook up, but unless you don’t have much overlap in your PTO shaft, there’s a good sized sweet spot where you can leave it back far enough to hook up the PTO without the shaft coming apart.
That’s not exactly what you asked, so if you found that useless, my apologies.
2,931
1,044
It would be easier to advise if we knew what you have for a tractor? Quick hitch for a BX is different than a hitch for a M8 series. It’s like asking if the tire for your 10 speed bicycle can be used as a spare for your Harley motorcycle. Also, Goodworks Tractor is expensive on those hitches. Can buy them a lot cheaper at places like TractorSupply.
GrumpyFarmer
3,993
Good day.
@MOOTS is shooting you straight. Make sure to check compatibility with QH before buying or trimming the PTO shaft. Measure twice cut once.
I am using Pats with my B and WC68. If you would ever have to disconnect the implement off the concrete in soft /really uneven area, have fun trying to reconnect that with a QH… just saying.
Good Luck
Sidekick
Jul 29, 2023
995
1,331
N.Y,
I bought the speeco e hitch and it's not a perfect combo. Still needs cat 1 to cat 3 top bushing plus not all my implements atr speed hitch compatible. Works great but still having to play with the top link location due to old implements. If all your implements are quick hitch compatible with top links that can be adjusted to the same location, nothing beats it. I still have to remove it for some implements to fit and pto shafts that were sized without the extra 5 inches. I also have an hydraulic top link that has been a game changer.
8,809
Good Luck
Not if you have top-n-tilt. 😂
A Quick Hitch without top-n-tilt is like a peanut butter and jelly sandwich without the jelly (jam). :)
I have top-n-tilt on both tractors and would never be without that feature. Not only do they make a QH unbeatable (with QH compatible implements of course), they are a huge upgrade for any implement that requires regular adjustments to the top link, or the side link, or benefit from floating the top or side links.
GrumpyFarmer
3,993
You got me there. 😂
must be jelly, jam don’t connect 3pt like that!
(I’m taking a half step to your solution on the big girl soon…just need some alone time with here to install - forgot my box wrenches last time 🙄)
8,809
You got me there. 😂
Take a full step! 😂😂😂 You won't regret it. I often put the side link in float mode for the snow blower, flail, rotary cutter, grading scraper, box blade, etc. It allows a rigid implement to better align itself to the terrain ... if that's what you want.
ben_2000
17
San Francisco
So the issue I had was connecting the lower arms, which I think was due to a combination of factors
  • Bushings (on tractor) were new and had overspray in, so the pin was very tight to begin with.
  • I did not realize how aligned the tractor and implement needed to be, I think I was off by a few degrees and they would not go in. I ended up shuffling the tractor 1/8 back and forward at times.
It does not help I am doing this all on my asphalt driveway, which I dont want to grind up moving things forwards and backwards.
Oh and I have not tried to hook up the PTO yet! More fun this weekend
Pats quick hitch also looks like a good idea.
Ben
mikester
M59 TLB
Oct 21, 2017
3,876
2,522
www.divergentstuff.ca
Just a heads up - My speeco cat1/2 will make contact with the PTO shaft on some implements.
I wish I had a trapezoidal QH for more PTO clearance. I had to modify my speeco to make it work on most of my implements.
