kubota 2001 b2710 start issue
b2710 M
b2710 2001
May 12, 2025
michigan
So I was removing my pto rototiller attachment and it was being a pain as usual, I removed all the different pins and was pulling fwd to disengage the pto shaft and it was sticking, then my tractor stalled as I didn't have the throttle high enough most likely.
After the stall I went to restart like a hundred times before and I can't even turn it over... all the lights come on it just wont engage at all.
Any thoughts greatly appreciated
mark
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
423
166
Attalla Alabama
mossycreekoutdoors.com
Most likely a safety switch. Seat is common. But also make sure pto is disengaged. While holding key in start position wiggle pto lever and gear selection lever and hydro pedal see if anything changes
