Box blade tips
Bearcatrp
Mar 28, 2023
776
428
Minnesota
Been watching some videos on operating one of these. Will be my 1st time. One video showed raising the front so the blade won’t dig in to deep. Would like to hear from you seasoned box blade owners on anything I should do and don’t. Appreciate any help. It’s a 48 inch land pride box blade I picked up for $595. Will be using my 1880 to pull it.
NorthwoodsLife
Oct 15, 2021
1,113
1,046
Wisconsin
You'll make a mess with it before you figure out how to use it correctly.... You'll need to adjust the toplink a whole lot to learn how it works. You'll wish you had a hydraulic toplink much sooner than later....
^^^This^^^ But don't be discouraged.
What, exactly, do you want to accomplish with it? Your answer will help all on here with experience, and help you get where you need to be faster. It's not rocket science as you know, but a lot of trial and error time can be saved for you.
3,279
Every situation is different, however, I will point out my "mistake" when using mine for the first time.
I wanted to smooth out my gravel drive. There were some small, uneven areas developing.
So I put those ripper shanks down to "rough up" the surface, thinking that it would "speed up" the process.....
Well all that did was "pluck out" a sh!t ton of big ass, ankle breaker, rocks.
I should have just used the 'blade and box" to lightly go over it.
I got way to aggressive with it.
Don't be in a hurry.......Go slow, and take your time.
Thats my $.02
Ping
BX2370-1
Dec 25, 2018
329
280
Troy, Ohio
OP,
I'll add that with the BX Series, we don't have position control so you'll need to be aware of your box blade height each time you lower it. You'll eventually get the hang of fiddling with the 3pt control to get the height even between consecutive passes. Also, if progressing across really uneven ground sudden changes in elevation can cause problems. For example, as the front tires roll down into depressions (think driving across a small ditch) the back of your box blade will raise up causing you to deposit unwanted material.
Good luck, hope this helps.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
211
161
Indiana
...as the front tires roll down into depressions (think driving across a small ditch) the back of your box blade will raise up causing you to deposit unwanted material...
For me, using a box blade on a gravel driveway, this was the most annoying part. I can't say I've ever totally solved it either - as far as I can tell, it's just a basic limitation to a rear-mounted implement on a small tractor. (pushing the fill backwards at least on a few passes does help, though)
It is THE reason road graders have a long wheelbase.
As Scissors notes, go slow. It's definitely possible (actually likely) you and a box blade will make your gravel driveway worse, at least initially. You need to get proficient at 'feathering' your 3PH lift control. Sometimes slow forward speed and 'float' helps.
All this assumes OP is using the box blade on a gravel drive. If it's to be used for grading or backfill around new construction, for example, a different 'learning process' is at play.
All that said, the box blade has been a great value for me - I've pushed and pulled around countless tons of misplaced material, with generally good results.
old and tired
L2800 HST; 2005; R4
One more thing to add... that back dragging the heel of the FEL (with a load in the bucket and in "float" mode) will help smooth out mistakes faster than trying to make everything perfect with just the box blade!!!
If you don't know what float mode, just ask...
For those that are new, pushing the joystick forward, lowers the bucket but if you push it further forward, it will click into a detente which holds the joystick in the up most position allowing hydraulic fluid to flow in and out of the lift cylinders freely, not putting down pressure nor carrying any weight. Using the heel of the bucket, dragging backwards feathers out rough sections.
Bearcatrp
Mar 28, 2023
776
428
Minnesota
Just want to trim down high spots and fill low spots. It is a gravel driveway. Don't plan on using the hooks. Thanks for all the replies.
BBFarmer
Jul 12, 2024
222
400
Terry, MS
This is so true!
powerkraut
Bx2230
Apr 13, 2025
12
Usa
On these tiny tractors I find it a lot easier to use the bucket to do the heavy lifting of knocking down high spots and filling low and then just using the box blade to finish. As others have said, a short wheel base will leave you constantly adjusting the box blade with every bump and dip.
Bearcatrp
Mar 28, 2023
776
428
Minnesota
I made sure when I bought this tractor it has a float mode. Used to operate large loaders years ago. Was using it yesterday on a few spots in the driveway. Want to get it as level as possible before bringing in some class II. Has someone plow my driveway this past winter. Didn’t know he used his blower. Have about third of my class II I laided down last year blown into my yard. Allot of raking coming up.
Grandad4
Apr 5, 2016
359
105
Greensboro, NC
The short wheelbase comment is very true. I often found using a crosshatch, or X, pattern helped make an area more even. If you just go back and forth, it's very hard to get the height adjustments just right so you gather material in the high areas and deposit it in the low spots. You can even end up making the dips and humps worse instead of of better. By alternating between back/forth and crosshatch you eventually get an area that is more flat.
trikepilot
B2620HSD w/ LA364 & BH65, 48SQ Bush Hog, LandPride RB1560, Woods 5ft Box Blade,
Jul 18, 2020
42
36
Hardy, VA
SOOOOO True!!! I just got a rear hydraulic toplink installed and it makes a world of difference. Some weight on the box blade, I feel, also helps with adjusting or feathering the blade/ground contact to get it to effectively do what you want. And you will most definitely screw things up on the driveway as you learn. The good thing is - it is gravel and easily moved back into place. I have 0.6mi of gravel driveway to maintain. I have found the box blade best for the heavy lifting of repairing ruts, spreading new gravel, and re-crowning. For the more frequent "dressing" of the driveway, I picked up a stout drag harrow that lets me quickly and easily smooth out the gravel. The box blade and drag harrow complement each other very nicely. Tines down to rough up and redistribute gravel and then tines up to smooth it all over.
Blue2Orange
Apr 3, 2025
52
17
Bayview Township
Also a newbie to box blade. Couple decades of just using a back blade to "smooth" out the driveway and trails. The transitions from up to down and down to up have been at times challenging. Lot of smoothing "back blading" with the loader bucket.
Dealer shop person noted he used the scrapper box to "level" his driveway. Available for rent at the dealership. If just minor valleys and high points vs. deep wash outs. Best maybe to use the scrapper box to level everything before using the box blade to spread new gravel?
6,328
With some practice with the top link, and the "quarter-inching" of the BX , you can do a lot with a box blade.
Give it some time. Go slow.
These are a couple different iterations of driveway maintenance at my place.
I was able to shorten the top link to dig and get the grade I wanted on the driveway. Then lengthened the top link to smooth things out.
I try to keep the current grade, so usually just smooth/level things out with a longer top link.
johnjk
Apr 13, 2017
1,537
1,444
West Mansfield, OH
A few things I learned. You need to break up the holes, not just fill them. Multiple trips across these areas to loosen up the compacted rock. You will spend more time than you think mastering this tool. A full 4’ box blade will bog down your tractor. My B3200 will start spinning in 4WD with a full box. Leave the FEL on and carry a full bucket for front ballast weight. After 5 yrs of doing my drive, I feel OK about my box blade skills but I still went out and got a land plane last year. Best purchase ever for driveway maintenance.
4,441
If you haven't seen this one, I'd suggest you watch it.
Dave offers great advice in this video...
