Diesel mushrooms
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,121
1,109
E.
almost everyday it seems we hear about diesel fuel contamination. so I cut and paste for s&g's i put together the following for those who have been lucky so far.
Quote:
Diesel bug is contamination of diesel fuel by microbes such as bacteria and fungi
. Water can get into diesel fuel as a result of condensation, water penetration AND adsorption from the air
if you buy biodiesel this form of diesel is especially hygroscopic
sulphur in diesel helps prevent the bacteria. so if you are a low sulphur diesel user this natural preventor is no longer present which used to help prevent
what is diesel bugs / fungus?
microbes that live at the transition between water and diesel fuel some call these microbes diesel fungus / diesel virus or diesel snot.
is a potential risk to your engine's fuel system, can cause serious damage and eventually lead to engine failure.
if fuel subjected to variations in weather and temperature or your fuel has been stored for more than aa few months then there is a considerable danger that your fuel may be contaminated.
contamination from water
water is the most common contaminant usually building up from condensation.
biodiesel is hygroscopic (it attracts water molecules from atmospheric moisture) so doing NOTHING is no longer a best practice.
Low sulphur diesel is more highly susceptible versus high sulphur diesel as the sulphur kills the bacteria
Fuel containing any amount of water could seriously damage your equipment’s fuel injection system and would make it more prone to breaking down.
Diesel has inherent bacteria in it. A little water from the atmosphere or contamination starts the growth of this bacteria and the mushrooms. It now breeds and multiply quickly and can easily and completely plug and block a fuel system.
The internet is full of these pictures and stories.
The bacteria will form a layer between the fuel and the water.
It breeds there producing waste which manifests itself as slime, sludge, black/green snot.
Once the bacteria colony grows to a certain load level it will settle out and fall to bottom of tank plugging hoses, filters, increases corrosion, damages pumps, etc.... sometimes very very quickly as the colony sinks from this layer between water and fuel to the bottom of your tank getting sucked into the internals.
Eventually engine will stop and may let you restart, maybe run for a short period of time then kaput!!
there are many things we can do.
- keep fuel clean, tank full, filtered and fresh and seasonally suitable.
- Since water sits at bottom of the system drain regularly if there are drain taps, replace filters more frequently than in the past
- avoid temp changes that minimizes condensation (frequent short trips from heated spaces to unheated work places if a big no-no if trying to avoid problems)
- am am now embracing tank cleaners, biocides, filters more than ever. Never used them in the past but the world has seemed to change
- I added a fuel polisher to my storage tank.
all stuff the larger fuel users have learned in recent years. Just sharing with the smaller tractor users who don't get a lot of hours on their machines so maybe not yet seen this sh@t first hand yet.
cheers
Reactions: 11 users
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,522
548
YIKES! I'm sure glad I have good fuel in my area. I have never had any kind of fuel issue and I keep 400 gallons here in my tank all the time.
amschind
Kubota M6800/Westendorf TA26, IH 82, NH 648
Sep 30, 2024
46
26
Bread without preservatives gets moldy in about 2 days, so my idea was to run little UV LED strips inside the breadbox hooked to a tiny 5VDC wall wart. I threw my test loaf away after about 6 months; it was hard enough to kill a man if thrown with sufficient velocity, but it didn't have a speck of mold on it. So why can't we put UV LEDs into a diesel tank? I think that a dry gas purge would also be a big deal as that will dovetail with the LEDs for preventing biological contamination and would be needed anyway to keep water out, but neither of those things are outrageously expensive.
The UV penetration through diesel will be degraded, and I'm not sure if the red dye would interact with UV wavelengths at all (dyes normally interact with a fairly broad spectrum, and often have other peaks). I think the easy way would be a big mesh frame with an LED strip wrapped around it fed down into the tank through the fill cap with a wire lead running out to a power source. The scientific way to do it would be an LED at the bottom of test tubes filled with various depths of "wet" diesel to determine the distance at which the LED prevented growth.
10,858
You test it and let me know if it works.
Easy way to UV treat the fuel would be to make a scrubber circuit with a flow through element.
One issue is most UV treatment units have glass elements and don't like to be shaken.
amschind
Sep 30, 2024
46
26
I agree, thought UV exposure is a time based kill. Meaning that residence time within the loop is the decisive factor, such that for a reasonable pump flow rate, you would need a length of pipe arranged in a labyrinth. As a practical matter, how hard is it to feed baling wire through a coil of copper tubing?
jyoutz
Jan 14, 2019
3,621
2,713
Edgewood, New Mexico
Seems like the biological treatments are a much easier solution.
10,858
If you used a scrubber circuit you would continually recirculate the fuel so the fuel would keep being treated, constantly killing the bacteria that is trying to form.
Really as @jyoutz said one added treatment in my storage tank lasts a long time!
amschind
Sep 30, 2024
46
26
I think that's great news, and I'd be thrilled to keep using diesel additives, but most folks that I talk to think that diesel additives buy you at most a year of diesel storage. I would prefer to buy 250-500 gallons at a time when the market dictates and then use that over a period of YEARS; that makes a 1 year shelf life a very limiting factor.
Have other folks had different experiences?
10,858
I have 250 gallons that I treat when I fill it and yea I've gotten 2 1/2 years out of it.
You could just add treatment once a year and still be way ahead.
I use Stanadyne and Soltron and that's it.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
We used a 300gallon bulk tank for decades with no problem. Got filled just before hay season and contaminated four tractors. After cleaning, flushing, biocide, many filter changes switched to 5gallon containers. Another neighbor had similar experience so maybe a supplier problem?
Last year started new again with smaller bulk tank. Don’t farm as much but 5gallon containers got harder to handle. . Did notice many of the older 5gallon bottles were getting a black inside after 20 years.
Make sure bulk containers have pressure/vacuum vent to limit air exchange thus limiting moisture collection.
Now treat 110gallon batches with biocide and diesel additives. Cheap preventative maintenance. PriD is a good diesel fuel stabilizer. Impressed with PriG for gasoline.
10,858
I'll second this, mine has biometric valves controlling pressure and vacuum.
jyoutz
Jan 14, 2019
3,621
2,713
Smokeydog
Jun 2, 2020
757
729
Fit 2” bung, 2”NPT and have 3/4” NPT adapter. Also can use a fill port. Closed top 55gallon drums have both.
amschind
Sep 30, 2024
46
26
I would have no problem doing a dry nitrogen purge over the tank. N2 is cheap.
10,858
Where do you install those on a storage tank? Are they the same size/ thread as a normal bung?
Yes the same bung size as a 55 gallon drum, other tanks will vary.
I have a 3/4" version on my tank.
WAS BANNED FOR NSFW PICS
5,162
At $115.00 a bottle or two of diesel biocide is a much better deal.
I had about 300 gallons of home heating oil left in my underground tank that hadn't been used in a few years. When it was pumped out into 55-gallon drums and used in diesel engines it was fine with no bacteria growth. When the tank was removed the contractor commented on how clean it was on the inside and no rust. My oil furnaces both were set up with a recirculation system that returned any fuel that the burner didn't use to the tank. I changed the fuel filters once a year.
4,143
Biobor JF is a Twenty-Mule-Team product which was mfr’r and FAA approved to use in my employer’s jet aircraft fuel tanks. I use it in my diesel storage tanks for years and have never found “bugs” in my fuel.
For less than $60…. (costing .03 cents/gal of diesel)…. it will treat your diesel and add lubricity as an additional benefit for low-sulfur diesel. An 8 oz bottle will treat up to 640 gals at the rate of 1-oz per 80 gals recommended.
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
Or you can get rid of the water:
Contains a desiccant that absorbs water but not diesel. When it's full, remove and hang to dry before reuse. I have a second that I swap in.
They also make a mini version that I use in the tractor fuel tank. Same deal: swap them out and reuse after drying.
(Actually it works well with gasoline too so I have them in all the marine tanks -- marine use is particularly susceptible to moisture and this darn ethanol fuel just aggravates the matter. )
