I am hoping to get some help... I am really stuck. The injection pump (high pressure pump) on my L3240 w/D1803 engine is not putting out any fuel. Fuel gets to the pump, but nothing comes out.
So I have disassembled down to the fuel injection pump, but cannot get it out. I have been working on this for weeks and cannot figure out what I am doing wrong. I have the WSM manual but there is no detail on this removal. I will insert several photos, but one in particular shows a bent "rod" that I removed from the pump area when I removed the threaded thing (sorry, don't know what it is called) that is about the size of a spark plug. I'm guessing that "rod" is not supposed to be bent like that.
I can rock the injection pump back and forth, but it will not come out. It's like something is holding it. I can see another horizontal "rod" (marked in photo with a yellow arrow) that might be what is keeping the pump from coming out, but I cannot figure out how to move or remove it. I would like to remove it so I can clean, test, repair or replace based on what I find or what a shop can perhaps do.
Hopefully my dilemma will make sense to some of you. Thanks so much. --Walter
