David Bradley Pull Type Adjustable Blade
billrigsby
Mar 17, 2015
1,004
161
Florissant CO USA 8213'
www.facebook.com
Tack welded in some 3/4" washers and two new 11" bolts,
nothing rides on threads and the slop is gone
Was a real bear getting it all lined up, a one man show with floor jacks, come-alongs and a demo bar,
also nursing a recent shoulder injury/repair, but it is together - never to be apart again at least by me
Had a new pin in the 'metal pile' from an old chipper, a perfect fit and not bent
3" ID washers should be here Tuesday to take up the final slop in the main pivot point
billrigsby
Mar 17, 2015
1,004
161
www.facebook.com
Got the Big-Ole washers today, that's a lot'a steel, that's why they are $5.75 each
Takes up almost all the play, still rocks a tad-bit but 1000% better
and a much solider ride I am hoping,
raining now so it'll wait for another test run
billrigsby
Mar 17, 2015
1,004
161
www.facebook.com
Added a set of thrust washers and a bearing surrounded with a rubber o-ring as a dust seal
I did not like the idea of the three point draw bar riding directly on the pintle insert
I think I am done with this at this point, paint, maybe next year
billrigsby
Mar 17, 2015
1,004
161
www.facebook.com
I was able to find a little information on this piece.
Was made for David Bradley somewhere around Lubbock Texas and
sold through the Sears catalog in 1958!
4,331
sold through the Sears catalog in 1958! View attachment 124830
Sure hope you still have that!
No need for me now, but I would have loved that when I had a 2,000' driveway.
Used an EA "6 Way Deluxe Scrape Blade" instead, with very good results.
Was also considering a "Huber Maintainer" at the time, but never did find a good one of those.
That would have been a lot more expensive though.
billrigsby
Mar 17, 2015
1,004
161
www.facebook.com
Yep, mine is about 850', it is a great help!
Hopefully gets some paint this year.
bird dogger
Vendor Member
Feb 24, 2019
1,577
1,427
North Dakota
Bill, that's already turning out to be one nicely restored grader!! Especially with your improvements added!
I don't have much use for mine anymore (see post 17) but when its needed it still works great....still in all its rusted glory! LOL! I do need to replace the wood and straighten out the rear stand for the assistant to stand on and operate the tilt wheels. One day....hopefully.
David
