Hi guys, I know my Tractor and loader are obsolete. It's been a great machine since I purchased new in 1993. 2430 hrs later, An unusual thing happened in this last snow. I rolled toward the snow pile with the boom up and bucket dumping a load. The tractor slid into the snow pile with the bucket at full dump position. Not real hard or anything real unusual but.... at high rpm, the bucket did not want to curl back? It was moving to curl position very slowly and straining the pump. all other functions are normal. After a full curl back, at idle the bucket tilts forward and curls back smoothly. raise the rpm's and it strains to curl back again? I reversed the bucket lines and it seems to move smoothly. It's a but odd to see it operate in reverse and since the loader valve has the "speed dump" feature. (Regen?) Anyhow, today was nearly 40 degrees and I tee'd a 3000psi pressure gauge on the lower bucket cylinder hose. (the curl) and when straining to return I saw about 1600 psi. I then decided to swap the hoses on the valve right to left and let the boom spool power the bucket cylinders and the bucket spool power the boom. this worked fairly well but so backward. I actually loaded a bunch of snow this way and got the hang of it. The cylinders seemed to function normally leading me to believe the valve is at fault. when I returned home, I swapped the hoses back to normal and the trouble returned. At any rate, I understand that an aftermarket valve is in order and I need to decide regen or no regen (speed dump). I dont mind this swap but I really would like to know what went wrong all of a sudden? Hoses are new, fluid level correct and was changed about 100 hours ago. any idea what failed in the valve block? linkages are tight and spools move and detent as they should. strange one for sure. I would appreciate any insight. thanks so much.
