Lube Survey
weaponoffreedom
KX91-3 L2501 RTVX900
Oct 8, 2025
nc, usa
In your orange stuff, what lubes do you use? Gears, engine, axles, drive units etc?
Weights?
Intervals?
ETC.....
I typically use 15w40, of whatever brand has enough on hand for 3 machines in the engine. Napa, Supertech, Delvac.........thinking of running 10w30 though, maybe not
Drive unit in KX91......Mobilube 80w90
L2501 Front axle....still running the factory fill UDT2, but thinking on 80w90 or even 80w140 as the front axle has a bunch of stress at times.....I tend to pick up more than what I should.....even with a weight box in the back, I find that it wants to dolphin.
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Good question!
In my L35:
Coolant: Rotella ELC Antifreeze Concentrate
Oil: Shell Rotella T4 - 15W-40 Change yearly
Hydraulic: Tractor Supply Premium Universal (been in there about 4 years - still clean)
Grease: Mystic JT-6 Multipurpose #2 (before a job I check and apply as necessary)
Front Axle: Supertech or similar 80-90wt (Been in there about 4 years - changing this year)
Filters: Kubota (thinking of changing Hydraulic filter this year)
In my RTV-1140CPX (Just restored this machine in 2024)
Oil: Shell Rotella T4 15W-40
Hydraulic: UDT2
Grease: Mystic JT-6 Multipurpose #2 {On linkage joints etc as required)
Front Hubs: UDT2
Filters: Kubota
Shawn T. W
Dec 9, 2024
775
1,405
SW Missouri Ozarks
Engine - Rotella T6 5W40
Hydraulics - Kubota SUDT2
Front Axle - Lucas 85/90
Coolant - Peak Final Charge Pro Series
Grease - Lucas Red & Tacky
Change at half of what the manual calls for, except coolant.
BAP
Dec 31, 2012
3,155
1,280
If you do a search on here, there are almost unlimited threads on the topic of lubrication and lubricant brands.
Mowbizz
Bx25d
Aug 19, 2021
612
357
Grease and oil! Doesn’t matter which to me (or my BX) going on 15 years and she has never let me down! 🤣 Even has the original battery! Now I’ve gone and jinxed myself! 🤔
Bearcatrp
Mar 28, 2023
1,361
985
Minnesota
For now, I get my oil from the dealer. Don't want to chance a denial of warranty claim if needed. Once its paid off, will be looking at other options.
nbryan
Jan 3, 2019
1,418
937
Hadashville, Manitoba, Canada
Shell Rotella T6 5W-40 - engine
Kubota Premium UDT (Canada) - tranny/front axle
Lucas X-Tra Heavy Duty grease - all greasing
Fluid Film - all lubing
and (not a lube?):
Sea Foam - diesel treatment
11,758
I get beer and crisps ... :ROFLMAO:
What brand of beer and chips (crisps) do you use? What flavor of chips, what's the alcohol content of the beer and what's the interval between beers? 😂
Hugo Habicht
G1900
Jun 24, 2024
1,536
2,200
Ireland
Crisps are "Chio" paprika flavour (imported from Germany). Beer is "Murphy's" Irish stout (strangely enough much cheaper in shops in the US than in Ireland). Interval depends on what is been written in this thread :ROFLMAO:
10,941
Cheddar and Sour Cream with a Cider...
Effen Tangerine Vodka and Sunrise Monster when dealing with forum issues.
BAP
Dec 31, 2012
3,155
1,280
What kind of oil do you like your chips fried in? That would be a good thread. Best oil to fry food in.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
REAL potato chips are potatoes, lard and salt here in Lancaster county where "if you ain't Dutch, you ain't much" :)
I do enjoy the occasional bag of BBQ, Dill, Jalapeno, etc.
3,047
From what little I know corn head grease is NLGI 0 so not as runny (thin) as the 00 grease.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
412
307
NH
I also use SUDT2 but only the stuff I drain out from a fluid change. That stuff is too expensive to use new for french fries!
Forgot to mention, I filter all the metal particles out before using the oil for frying.
A lot of metal particals, is that a bad thing? :unsure:
11,758
Oh the irony, since we're normally talking about oil that won't fry stuff such as the transmission! 😂
