Kubota L2550 lift arm problems
John Eaton
L2850
Mar 3, 2023
Ruthin
I've had my l2550 for a year know and in all that time I've had the kms180 backhoe attachment on which it came fitted with. I just took the bars which lock the lift arms off, which I assume are part of the backhoe attachment, to see if the lift arms work, and there is no movement at all in the lift arm! Is there something else that would need reconnecting/switching in order to get them going or do I have an issue with my hydraulics, seazed maybe? Cheers Paul
9,307
The lift arm should look like this.
Have you opened the drop speed / lock knob?
2,393
As I understand your problem, it is the short upper arms are not moving. So if they are all the way up, then they may just be locked in that position and turning the knob may fix it.
But I also think that the hydraulics to the three point hitch are SOMETIMES changed when the backhoe is on so that nothing can get damaged accidentally. So find your operation manual and read it for installing and removing the backhoe. It may be in the tractor manual or in the backhoe manual.
The tractor manual is available here if you need it (for a small donation)
