So if no one knows, who does ? As recommended posted video
docstoy
M9960D
Aug 19, 2025
17
Kentucky
I asked a question about my M9960D Trans. or gear noise with no response. So besides taking tractor to dealer and them guessing, what website or who may know ? Not trying to be a smart Alec , would just like to be knowledgeable about problem. Thanks
3,260
1,682
I could come up with 3 dozen or more, could be this or could be that, I just can not hear the noise from here.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,739
2,091
Near Lancaster, PA, USA
My guess is that Wolfman has some things going on that have limited his screen time and:
1. Very few other people who frequent this board are very knowledgeable on the shuttle shift tractors.
2. Those who are, it would probably like to hear it.
3. Nobody wants to provide incorrect answers.
3,638
Sorry, I missed your original post. So, here’s my diagnosis…and how to solve the problem:
It’s a bad gear-noise in your transmission.
Buy a good set of headsets, preferably with Sirius Radio, and turn the Volume UP on your favorite music.
IF/When the tranny finally breaks completely, the dealer will not have to guess about it at all.
You’re welcome.
Reactions: 6 users
5,150
It would help if you could take a short video of the tractor making the noise and post it so folks can hear the noise.
You can’t directly post videos here. Post a video to YouTube. Post the link here.
Fedup
329
127
Winchester
Looking at a video and listening to noises makes about as much sense as showing a photo and asking what does this feel like?
9,192
You need to make a video / audio of the noise post it on Youtube, then give us a link to see / hear what's going with it.
Being a cabbed model you will always get a higher sound level than a non cabbed model.
FYI: There are some of the best Kubota techs out there on here, I don't know of anywhere else that you'll get better answers than here.
docstoy
M9960D
Aug 19, 2025
17
Kentucky
I'll get a video posted as soon as I can, will have to get one of my children to do it
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
228
246
Pennsylvania
I have a very good dealer here...when I run into a problem, I give him a call, tell him about the mystery problem. He sends a tech to my home to check it out and offer a remedy ..No remedy, no charge...now that's service and, caring.
My dealer
For over 100 years, Erb & Henry Equip., Inc. has been the areas leader in the Agricultural Equipment for residential and commercial lawn and garden equipment sale. At Erb & Henry Equip., Inc, the difference is that the sale is just the first step. We service what we sell, which means we're here for you after the sale. For over 100 years, we have built our reputation on providing the best possible service!
Great to have a caring dealer on hand.
JasonW
533
313
Al
I guess I’ll be the first to ask. Why are you putting the shuttle in forward or reverse with the gear shifter in park?
I read that in your other post and it didn’t make sense to me. The video helps though.
My M series make some noise with the shuttle on forward or reverse with my gear shifter in neutral. Possibly just a balance/idler shaft?
docstoy
M9960D
Aug 19, 2025
17
Kentucky
The reason is the m9540 doesnt make any noise but the m9960 does . Don't know if it will break but would rather fix it now before it scatters pieces if it needs it.
JasonW
533
313
Al
Both have the same 4 speed transmission with park?
3,260
1,682
I would change the hydraulic filters, cut the used ones open, and inspect the pleats for metal.
docstoy
M9960D
Aug 19, 2025
17
Kentucky
Hydraulic filters and fluid have been changed with no change. This tractor has the pto engagement switch that rotates to engage pto and I assume it's supposed to be a gradual increase in pto rpm but it's not pto engages all at once with noticeable engine rpm drop . I spoken with the dealer about both problems and he did give me a bulletin about replacing an orifice it is in PSB-2016-008-R1 . Service manager also said that M9540 and M9960 were different in that 9540 uses a dry clutch and 9960 uses hydraulic clutch . And he also stated it could cost 10k to 15k to repair noise . I have ordered orifice to see if it helps pto . While I'm there should I look at or ck anything else ? Thanks for any suggestions .
3,260
1,682
Did you cut open the filters and see what, if anything, is in them?
9,192
Did you do as @whitetiger said and cut the filters open and look for metal in the filter element?
EDIT I'm a slow typer
docstoy
M9960D
Aug 19, 2025
17
Kentucky
Hadn't looked at them before today , these filters have magnet where filter screws to housing. Haven't cut one open but stuck to magnets there are a lot of shiny pieces of metal as well as several pieces that are slightly curved and rolled and are 40 to 50 thousands thick and around 800 thousands long . Is the transmission case open or is it sectioned for different functions ? Dont know how fluid flows thru case, could damage be confined to one area ?
