Messicks, reinvents black electrical tape/duct tape.
JenniferKubotaM62
M62 TLB, Bobcat HD Grapple, Bobcat Auger, Skeleton Bucket, Forks, WB Ripper
115
Arizona
www.jenniferbond.com
Awesome…. And in true Messicks style, it’ll be $19.95 for the part and $167.59 shipping. 🤣 To be honest it’s cute giving him a use for his printer and teach him some business skills, so I’ll probably buy one to support them but thought it was cute.
Reactions: 6 users
9,218
Now that's funny!!
I think it's cute to see Neil so proud of his son. I spoke to Neil on the phone a few years ago and I was impressed by him. I think he is a great ambassador for Messicks and the Kubota brand and I always enjoy his videos.
Dustball
2016 B2650HSDC
Sep 15, 2023
436
293
Hudson, WI
It's $10 for the part and $9 for USPS Priority shipping.
9,218
I won't be ordering an adapter since the MX/M tractors don't lose much oil when changing hydraulic filters, but for those not able to design and print their own adapters, or those that don't like the rag and tape method, this is a nice option.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,730
2,075
Near Lancaster, PA, USA
Neat idea. Good for the kid. They'll probably sell a bunch. To reduce inventory, I wonder why he couldn't do something like the adapter below. I'll probably stick with a rag stuffed around the hose because there's always a rag handy when doing fluid and filter work.
lynnmor
B2601-1
May 3, 2021
1,632
1,412
Red Lion
I wonder if it is a good idea to have a perfect seal on the vacuum hose for two reasons. First, while removing the filter the suction draws debris inside and there is no oil to wash it out. Second, a high vacuum may pull debris in at any of the seals.
I have my better half hold the vacuum hose in the hole allowing plenty of leakage, you don't need a lot of vacuum to retain the oil.
The ad for the adapter says as much but I don't see where vacuum is controlled
WI_Hedgehog
Apr 24, 2024
750
985
Milwaukee, Wisconsin, U.S.A.
Unless your better half is going to hold my hose 😄, which I highly doubt, there are those of us who work alone and actually prefer to do so, and the adapter is a pretty good idea as tape doesn't stick to greasy metal.
BUT, as was stated I think a shop rag and some electrical tape is a better idea as that much suction is a bit much suction.
(Absolutely no disrespect meant to @lynnmor or anyone else)
5,726
meh. I'll stick to plugging the vent line with a pencil...I lose very little fluid that way. 🤷‍♂️
2,318
From what I see there is a flat surface that sets down onto the top of the neck. That is where it appears to “seal” to me.
lynnmor
B2601-1
May 3, 2021
1,632
1,412
Red Lion
I agree but there is no way to throttle the suction, I don't want maximum vacuum, just enough to hold the fluid.
Shawn T. W
Dec 9, 2024
341
607
SW Missouri Ozarks
Yay for his son!
Horrible music!
For $20 for a gadget to loose in the every 4-5 years most will use it, or if they can find it! 😁
Nope, not for me.
My shop vac has a couple of tapered ends, works for me!
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,611
2,077
Western MT
I think will be a very useful product for a lot of people. I also don't know how tape can replace the new product. Maybe OP can post a video of how electrical and how duct tape works. ;)
Nicksacco
Sep 15, 2021
727
447
Bahama, NC
Neil is a great ambassador for the brand!
I spent about an hour with him at the Mt Joy facility and he's just like he is in the video - personable and interesting.
Good for his son!
Reactions: 6 users
6,886
Yay for his son!
Horrible music!
Nope, not for me.
Yes, and if the tapered end needs to have an angle to fit somewhere just use a heat gun warm it enough to make the shape you need.
WI_Hedgehog
Apr 24, 2024
750
985
Drill a hole in whatever plastic tube or adapter you're using and put in a valve. If drilled low enough in the connector end of a vacuum hose the hole will be covered when connecting to another attachment, and/or the hole can be covered with electrical tape.
You could also drill successfully larger holes until getting the amount of suction wanted.
(example of the type of small valve)
